Old 04-28-2014, 07:54 PM
bigaudioal's Avatar
ONE OF MY FAVORITES!!!!!!
"I told you there would be no difficulty in building this aeroplane. I also told you it would require an outstanding pilot to fly it. The only thing outstanding about you, Mr. Towns, IS YOUR STUPIDITY!!!!!!!"
-Al
Old 04-28-2014, 08:01 PM
M3-SRT8's Avatar
M3-SRT8 M3-SRT8 is offline
Correct. Very good!
Old 04-28-2014, 08:03 PM
M3-SRT8's Avatar
"Ahhh..Lou..."
Old 04-28-2014, 08:14 PM
Originally Posted by batterymaker View Post
Flight of the Phoenix?
Old 04-28-2014, 08:19 PM
M3-SRT8's Avatar
"Oh, I thought it was all cut and dried...you mean you have a few little things you haven't figured out yet, huh?"
Old 04-28-2014, 08:28 PM
bigaudioal's Avatar
-Al
Old 04-28-2014, 08:34 PM
TV'S&MORE TV'S&MORE is offline
Did you remove high voltage cage and change out the .1 capacitor C50 and check the resisters R61 And R62 in there. These are sometimes overlooked.
Old 04-28-2014, 08:39 PM
M3-SRT8's Avatar
Old 04-28-2014, 08:41 PM
M3-SRT8's Avatar
Yes. I pulled the cage and replaced EVERYTHING underneath, except the variable mica cap.
Old 04-28-2014, 08:43 PM
bigaudioal's Avatar
https://www.youtube.com/watch?v=V0hIoLNecqI
-Al
Old 04-28-2014, 08:57 PM
M3-SRT8's Avatar
As a matter of routine I replace 1/2 watt resistors with 1 watt, and 1 watt with 2 watt.
Old 04-28-2014, 09:12 PM
M3-SRT8's Avatar
When I was a 10 year old kid, I used to design and build my own flying model airplanes. Obviously, "The Flight of the Phoenix" was one of my favorites. Still is.
Old 04-28-2014, 09:15 PM
bigaudioal's Avatar
I built two. The first was one of the ones that was attached to the string. So you started it up and you swung it around in a circle. Second one was a complete RC model. Loved them both.
-Al
Old 04-29-2014, 09:39 AM
M3-SRT8's Avatar
Now that she's burned in for about 10 hours total, I noticed the HV has climbed slightly past 4kv. Also the crackling sound is now limited to a brief time (3-4 seconds) on start up. No more tics.
I'm going to call this one done, barring any relapses. But since I've replaced all the caps except a handful of micas in the sound and IF stages, I don't anticipate that.
Old 04-30-2014, 06:14 PM
The HV improvement and reduced "tics" do point to possible slight flyback moisture or similar issues, don't they?
