Old 03-19-2014, 06:41 PM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Cute little Motorola Cadet
Funny, searched and there doesn't appear to be a thread on these sets.....
Picked up this cute little mint condition Motorola Cadet from a friend recently. Inadequate vertical sweep, tubes test fine and I replaced a couple .047 caps in the vertical sweep section to no avail. Thinking it might be yoke time, but I can't find a valid model number anywhere on the set so that I can source a Sams.
Old 03-19-2014, 07:35 PM
Did you test the vertical resistors?
Old 03-19-2014, 08:05 PM
Robb's Avatar
Robb Robb is offline
Nice. I like it.
Interested in selling it ?
flickr
Old 03-19-2014, 08:09 PM
The set is about a 66-67 model. The chassis number should be stamped in the edge of the metal PC board frame.
Old 03-19-2014, 09:50 PM
Kamakiri's Avatar
Didn't test anything. This chassis is rather packed in, and usually in such a situation I'll start by testing voltages and working from there.
Sounds to me like you know something about this set....care to enlighten?
Old 03-19-2014, 09:56 PM
Kamakiri's Avatar
Originally Posted by Robb View Post
Nice. I like it.
Nah, not at this point. I've sold or given to fellow collectors so much of my collection that I liked but never used (or never worked on as the case may be), so that right now I'm down to a total of 12 or so televisions.....my core of what I use and what I want to use.
Of that number, 5 are fully functional but I've done at least some work on all of them.....all but 2 are in the final stages of de-lousing (which is what as we all know takes the longest when we run into issues).
I watched the first liftoff of the Space Shuttle Columbia on a Cadet, sick in bed at my sister and brother-in-law's house, as a kid. Kind of a neat memory, and I think I'd enjoy watching and using this set
Old 03-19-2014, 11:06 PM
Robb's Avatar
flickr
Old 03-19-2014, 11:25 PM
Never owned or seen one in person(it's a nice little set though), but I've had enough sets go form having a completely lousy vertical section to a near perfect one just by replacing all off tolerance resistors (and am a cheap enough son of a gun when it comes to repair parts) that after tubes and caps in the vert. are confirmed good I go straight for the resistors before suspecting semi-unobtainium parts....Also if a somewhat costly part fails I've learned (the hard way) to look for the reason it failed in surrounding circuitry and generally make sure there is nothing going on in the surrounding circuitry that can readily damage that new part before running said new part.
Old 03-19-2014, 11:42 PM
Einar72's Avatar
Einar72 Einar72 is offline
Chasin roundies since '79
Stared at a stack of these the day White Front opened in Seattle in '67. Found one in a thrift storeabout1983, then took it to Utah in the overhead compartment on the airliner!
Old 03-20-2014, 06:15 AM
Kamakiri's Avatar
I'd tend to agree with you, but this thing has probably 1" of vertical sweep. I've found that (most often) little issues, little parts.....big issues big parts. While the set inside looks as mint as the outside, what I'm pretty sure is the vertical output transformer looks a bit gamey.....
Old 03-20-2014, 06:19 AM
Kamakiri's Avatar
There it is, thanks!
WTS-454YA-04....Sams 775-3, making this one a 1965
Now, to find one.....Sams website has them, but I'd like to find an original copy. Anyone happen to have one they'd part with/sell?
Old 03-20-2014, 09:58 AM
It looks like they used every square inch of space available!
I'll look if I have a Sams. I have a Supreme manual, that covers the set. They have them bound so well, they're hard to photocopy.
Old 03-20-2014, 12:58 PM
Kamakiri's Avatar
If whatever you have gives ohm out specs for the vertical output transformer, that'll get me started.....
Old 03-20-2014, 06:21 PM
It's an unusual design for a B/W vertical output transformer.
The resistance values, per Sams are as follows:
Between the blue and red: 250 ohms.
between the red and the green: 1.8 ohms.
between the green and the black: 17.8 ohms.
Disconnect the green lead from the yoke, to get the truest readings.
The transformer is an autotransformer design and has only one winding with taps.
Sams doesn't show any replacements for it, so hopefully it'll be OK.
Old 03-21-2014, 08:04 AM
They were fairly common sets. The antennas were always broken
out of the handle, Moto had a kit to fix that. They are crowded
& high milage ones dried up like a GE. Other than that they
ran quite nice & yours looks very clean.
BTW PM me if you dont find a free Sams.
