Old 01-16-2014, 06:06 PM
CoogarXR's Avatar
CoogarXR CoogarXR is offline
It does still have the original burners with the "lifetime" logo in the middle, and they all still work. I don't know how much it's been used over the years, but it's still in good shape.
I still haven't finished the install yet, or I'd put up some pics.
Old 01-16-2014, 09:01 PM
egrand
Guest
Posts: n/a
Originally Posted by Jeffhs View Post
I noticed in the ad for this kitchen combo that the stove has "permacoil" lifetime burners. I don't agree with that. Electric stove burners (and, of course, the oven's heating elements) do eventually burn out in time, depending on how much they are used. Either the ad for this Modern Maid combo unit was overhyped, or else the cooktop elements must have been made of incredibly thick wire that is guaranteed not to burn out for 50 years from the date the appliance is purchased.
I've never seen or heard of any electric stove with heating elements guaranteed to last a lifetime. The only way I can see the cooktop on this thing lasting more than, say, 20 years and still have its original elements when it was finally junked would be if the stove was not used much, "much" meaning only once every few weeks or so. Most stoves in homes with large families, of course, are used much more than that, so the Modern Maid combo's claim that the original burners will last a lifetime is probably, even likely, nothing more than advertising hooey. Some stoves have been kept going for years or decades by replacement of burned-out burners and/or oven elements (even though a 50-year-old stove in, say, avocado would look horribly out of date in a 21st-century kitchen, especially if a modern microwave oven is installed over or near the range), but to expect the original burners and/or baking elements to last anywhere near 50 years...well...
However, as others have mentioned, it is possible to keep these units going for years or decades by replacing old, worn-out components as necessary (as some VK members have done with old combo TV-radio-stereo units after the television develops expensive repair problems). As was mentioned, the dishwasher opening in the MM combo is a standard size, so almost any modern kitchen-size dishwasher will fit in it; as for the stove, as I said, the burners can be replaced when they eventually burn out, so it is conceivable that some of these old appliances will live on for a very long time, even after they are supposed to have been junked. The only drawback is that the styling will be out of date in modern kitchens, as I mentioned.
Why can't a heating element last 50 years or more? There are plenty of stoves and other appliaces out there that still have original elements that still work. Most stove elements are a coil of nicrome or resistance wire incased in ceramic and inside a metal tube. Sounds an awful lot like a resistor. There's plenty of old tv's and radios that still have their original resistors.
So long as the nicrome stays incased in the ceramic and not exposed to air where it can oxidize away, it should last a long, long tmie.
And, legally a lifetime warranty only means the average lifetime of the appliance, not the owner. So, probably not more than 20 years was it's reasonable expected lifetime.
Old 01-17-2014, 03:41 AM
You are quite right as to the longevity of burner coils and oven elements in electric stoves. I said in another post (and put my foot in my mouth in the process) I thought the wiring to the thermostat and heating elements in electric roasters (the large white ones often found in church kitchens in the 1950s-'60s) would crumble after fifty years; turns out these roasters have asbestos-insulated wiring (as the person who responded to my post informed me), and yes, the elements should last a very long period of time before burning out. It is probably more likely that the mechanical timer clocks in 50-60+ year-old stoves wore out first, with the burners still in as good shape as they were when the range was new. Many of these ranges are still in use today, the timer clock having stopped or jammed years or decades ago; but the stove's owner probably doesn't care, as long as the stove itself still works.
You also make a valid point regarding the definition of "lifetime" as applied to electric range burners. I did not realize that the term in this context referred to the average life of the appliance; in any event, you are correct. However, since burner coils (and oven baking elements) are made of nichrome wire and are encased in a rather thick spiral enclosure, they should, in theory anyway, outlive the owner of the appliance by many years. As I stated in the last paragraph, it is more likely that the timer clock and/or the temperature selector switches, or the oven thermostat, will fail long before the burners.
Old 01-17-2014, 12:23 PM
egrand
Guest
Posts: n/a
Jeff, I think it's a good point that a lot of times the associated wiring goes bad first.
I grew up with my mom cooking everyday on a circa 1950 GE Stratoliner pushbutton stove until well into the 1980's. IIRC a mouse chewed into the wires in the back and they burned out and dad said let's just get a new one since it didn't match their other appliances.
Old 01-17-2014, 02:02 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
So, by today's standards, that's what, six months?
Old 01-17-2014, 02:51 PM
CoogarXR's Avatar
That's kind of a self-fulfilling warranty. It's a lifetime warranty. If the item only lasts one day, well, I guess that was it's lifetime. No refund for you!
Old 01-19-2014, 08:59 AM
Countryford's Avatar
Countryford Countryford is offline
When I bought my 1949 brick home, the original kitchen was in bad shape. I ended up gutting it and remodeling it. I could have installed new granite cabinets and all that other over-hyped garbage. Instead I went with natural wood cabinets that have a vintage feel and went with a black and white tile counter top and backsplash. The kitchen, while not original to the house, does look appropriate to the house. Therefore my 1949 Hotpoint fridge and O'keefe and Merrit range fits perfectly in my kitchen/house.
Old 01-19-2014, 11:30 AM
electronjohn's Avatar
I like....big sparks!!
When my Mom & Dad were married back in 1949 they took some of their wedding $$$ & bought themselves a refrigerator. That International Harvester sat in the kitchen for years...then went to the basement after being replaced by a newer fridge complete with ice maker. The IH now resides at my sister's and is still icy cold. Dad fabricated a new door gasket years ago, along with brazing up a door handle to replace the pot metal one that broke.
Over 15 years ago we purchased a used Maytag washer & dryer for $250. I'm thinking early 70s with the woodgrain control panels. The washer continues to function flawlessly, and all I've had to do to the dryer is replace the heating element about 10 years ago and a new belt last year. As long as they can be repaired they'll never be replaced.
Ham shack...AM side: Knight-Kit T-60, RME-45
Vintage SSB side: National 200
Modern SSB: Kenwood TS-180S
MFJ tuner, 130' dipole
Old 01-20-2014, 12:46 PM
IIRC, the International Harvester refrigerator was made by the Ben-Hur Mfg Co on the northeast side of Milwaukee. Their products were very well built and used the best compressor.
The firm was owned by the Schlitz brewing family and it still in business, under a different name and a different location.
Old 01-20-2014, 10:58 PM
egrand
Guest
Posts: n/a
I thought I-H made their own fridge and freezers at a plant in Evansville, IN, which was later sold to Whirlpool. Maybe the plant you're thinking of made their a/c units?
Old 01-21-2014, 07:03 PM
davet753's Avatar
davet753 davet753 is offline
David Thomas
You'll never have to replace those machines. About the only thing you might have trouble finding down the road is a timer assembly, but those usually hold on for years.
About the only thing you'll see replaced on Maytag washers (from the 50's until the early 90's) are the pump and drive belts or a water valve. The transmissions are pretty much bullet-proof.
If the dryer conks out, it's most always something simple (element, limit switch, belt, etc.).
Old 01-27-2014, 08:38 PM
Jon A.'s Avatar
Duly noted. Perhaps I'll get a junk Chinese blender to do that with, and make a video of it. Of course it will fly apart a lot faster than the Philips shown above would.
Well, a suitable blender has surfaced, made under the once-respected name of Black & Decker. The only thing respectable about this blender is the glass jar. However, I'm not paying $5.99 minus my discount plus the cost of coffee beans just to watch the thing fly apart. The damn thing is priced higher than my Philips was.
Old 02-02-2014, 08:34 PM
Reece's Avatar
Reece Reece is offline
Timers can be fixed, too. Sometimes it's burned contacts, especially on a dryer. I have cut a brass strip complete with contact from a relay and soldered it in place of a burnt contact in a dryer timer, and back in business. Of course, worn gears or cams could be another story.
Reece
Old 02-03-2014, 08:05 AM
Just this weekend I picked up a 1990 Lady Kenmore washing machine and a 1970 Lady Kenmore dryer. The washer is Platinum(gray) and the dryer is Avocado Green. The reason I picked them up is I figured it was time for my 1963 Lady Kenmore set to get some rest. They have been good machines for the 7 years, that I've owned them. I'm not getting rid of them. I have a second laundry room that has hook-ups for 3 washer and dryers. They are getting placed out there to be used on special ocassions. I'll let the newer washer take the everyday use.
Old 02-03-2014, 08:19 PM
Jon A.'s Avatar
I'd rather pay for old, well-kept appliances than be given new ones.
