Old 10-30-2013, 04:09 PM
the radio Dizzy Dean used to listen to the game.
So what radio is this:
http://www.nytimes.com/imagepages/20...rts/KMOX3.html
associated press
The Cardinals' Dizzy Dean, in 1936, when radio brought the game to fans
Old 10-30-2013, 04:55 PM
truetone36's Avatar
electronics packrat
Looks to be somewhat high-end. Could be a Majestic or one of the last Atwater Kents.
Old 10-30-2013, 05:03 PM
truetone36's Avatar
electronics packrat
After doing some looking around, from the dial and knobs it does look to be a Atwater Kent set from C. 1934.
Old 10-30-2013, 08:08 PM
I believe that is an RCA. I think someone here has one with the legs sawed off.
Old 10-31-2013, 09:00 PM
Steve K Steve K is offline
Yes it's a Model 222 RCA from 1935.
Steve
Old 11-02-2013, 11:17 AM
Dennman6's Avatar
Dennman6 Dennman6 is offline
Nice looking set. You can see the antenna wire going out the window just behind Dizzy's right hand, behind the chair. Wonderfully amazing that such simple circuits(compared to today's gear), a bunch of tubes, & a length of copper wire could bring you the world. Great stuff!
"Take time to deliberate. But when the moment for action arrives, stop thinking and go in!"-Andrew Jackson
Old 11-03-2013, 03:42 PM
Yep, a 222. I'm the guy with the amputee victim Even so, it's a pretty radio I think.
Old 11-03-2013, 04:43 PM
Nuke Nuke is offline
Since that might be Dizzy Dean's set, might want to consider adding legs to it.
Old 11-03-2013, 07:01 PM
I definitely plan to add legs, but I need to find someone with woodworking skills first. I just don't have the equipment or knowledge.
There's also an oval shelf between two stretchers.
Old 11-04-2013, 12:37 AM
egrand
Guest
Posts: n/a
Were they actually sawed off, or was the base a separate piece?
At any rate, that doesn't look too difficult for a woodworker to recreate.
Old 11-04-2013, 11:34 AM
Here's a pic showing the laigs...
http://www.radiomuseum.org/r/rca_222.html
Old 11-04-2013, 01:20 PM
That set is truly an "Art Deco" design. Styling way ahead of it's time.
Old 11-04-2013, 08:41 PM
OK - I see what you mean. I have come across alot of stretcher bases that are bolted on. What you could do is keep your eyes open in a thrift store for an old coffee table or something and set it on that. Try to match up the size and legs. Or just use the legs. Drill a hole in the leg - shove a steel rod in there - drill a hole in the cabinet and glue the whole mess in. Stain or Laquer to match. Use the stetcher for additional support underneath. Maybe use the back of an old wooden chair for the oval. Just don't move it around once it is assembled. Or get as many pictures of the base as you can and talk to a furniture restorer if you really want make it nice. Experiment. Have nothing to lose. It would look 100 percent better anfd you would probably fool alot of people.
Old 11-04-2013, 09:38 PM
Might make a few bucks selling it to a baseball guy.
Old 11-04-2013, 09:40 PM
Also, what does Dizzy have on has radio? It looks like a little doily with a Buddha statue on it. Also, it looks like he has little figures on his shelf next to the radio?
