Old 07-18-2013, 10:42 AM
oldtvsandtoy oldtvsandtoy is offline
Banned
aaa
aaa
Old 07-18-2013, 10:05 PM
Have you looked at using modern diodes? I've heard plenty of stories about seleniums failing and stinking up the joint. I do have a handful of NOS and used seleniums but would have to check for the ratings.
Old 07-18-2013, 10:30 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Yeah, the smell will get into your furniture as well.
Old 07-19-2013, 05:55 AM
Banned
aaa
Old 07-19-2013, 02:45 PM
bob91343 bob91343 is offline
I find that the 1N4007 works for nearly all cases like this. You will also need a resistor in series with the diode, maybe 47 Ohms 2 Watts. 1N4007 diodes cost a few pennies each so buy a bunch for future use.
Old 07-19-2013, 08:52 PM
Banned
aaa
Old 07-19-2013, 09:34 PM
AdamAnt316's Avatar
Collector of heavy things
Originally Posted by oldtvsandtoy View Post
will that work for the .200a and .130 a?
1N4007 diodes can handle a full amp, so they should be more than enough to replace either of those.
Visit my site!
Old 07-20-2013, 01:44 AM
one 1n4007 for one selenium rectifier , one for the other , its pretty easy to do and more reliable since the nos ones would fail after a while anyway.
mike
Old 07-20-2013, 10:53 AM
Banned
aaa
Old 07-20-2013, 03:55 PM
A resistor is needed. See my post above.
Old 07-25-2013, 03:10 PM
Also not a bad idea to put a .01uF 600V film cap in parallel with the diode to reduce the increased switching noise inherent in modern diodes. It is called a snubber cap when used in this application IIRC.
Old 09-06-2013, 07:22 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
We sure could use a good tutorial on replacing these. I'm diving into a Halolight that is going to need them, and I've never done it before. Even a simple diagram would work
Old 09-06-2013, 07:42 AM
To begin with while you have a working selenium in place, measure the voltage drop across it, the current running through it, and the shape of the rectified signal. Use the current, and voltage drop to figure out what resistor to put there..... And the scope pic of the wave after it, when you put a cap across it, compare the new picture to the old one..... Call it engineering a solution.
Old 09-06-2013, 09:05 AM
Kamakiri's Avatar
In this case, this set probably hasn't seen a wall receptacle since the Nixon administration, if not before that.
I have to do a full recap on it, so let's assume for the moment that I can't do that
Old 09-06-2013, 09:17 AM
A couple things I do, if replacing selenium with silicon, I would leave a term strip setup for a B+ dropping (and fuse for that matter if it does not have one), then use a variac and start at about 90v see how the set behaves (this is assuming its working). if everything working check the B+ at the output of the rectifier to the sams check the current and get a ballpark figure for the dropping resistor using ohms laws, prob between 50 and 200 ohms. check your line voltage and fine tune the resistor to the correct B+
