Old 05-22-2012, 12:16 PM
47'Plymouth 47'Plymouth is offline
anyone can spare a 47uf@450 E-cap?
Hi Folks;
need a 47uf@450,E-cap for my Sencore SS105 sweep curcuit tester;
anyone could spare a new one,I sure appreciate it....
Jody
Old 05-22-2012, 01:30 PM
If you don't receive any offers, you could, if there's room enough, use a pair of 100uF 250V caps in series. Add a 1 megohm resistor across each cap, to be sure the voltage evenly splits across each cap. Works well, you need to be sure the upper cap is insulated from the chassis. Terminal strips and circuit board style caps is what I've used, below the chassis.
Old 05-22-2012, 02:22 PM
yes,I have a 100uf@315vdc,but the voltage is to low,kinda of large
in size,for a radial cap...a correct size would be better...thanks
Jody
Old 05-22-2012, 03:49 PM
That's why he suggested putting two 100uf in series. The capacitance will be halved to 50uF and the voltage rating doubled.
Old 05-22-2012, 06:53 PM
ohohyodafarted's Avatar
Bob Galanter
I don't have any but there is a ton of them on ebay
http://www.ebay.com/sch/i.html?_nkw=...450v&_osacat=0
ME http://AntiqueTvGuy.com
Old 05-23-2012, 12:05 PM
got to digging around and found one...100uf@450vdcand installed it...thought i was out...sorry my bad...got the Sencore working.
thanks.Jody
