Old 04-30-2012, 06:30 PM
jstout66 jstout66 is offline
Damn.. I looked and was over-run by Chromacolor parts, and only 2 System 3 Parts.
I would have given you the 9-160-05 if I had it
I do have a new 9-152-02 (which in 85 was the replacement sub for a 9-152)
Also.. a 9-239 which states Tunar control
If you end up needing the 9-152-02, let me know.
Old 04-30-2012, 07:15 PM
mrflex65's Avatar
mrflex65 mrflex65 is offline
Originally Posted by jstout66 View Post
you may able to check out the video source... most system 3's have a black wire that comes out the back that plugs into an area right by where the screws are for the VHF/UHF. If yours is so equiped, you simply unplug that wire (it should pull right out), and surprise.. your cable wire plugs into the end of that black wire.
Unfortunately mine is soldered in at the antenna terminals and then the coax plugs in the 9-151 module which is a phono plug.Is that what your talking about?
"IPC 610 Class E & J STD-001 Certified"
Old 04-30-2012, 07:16 PM
Old 04-30-2012, 07:20 PM
mrflex65's Avatar
also.. i see a PTS module online, but geezzz.. 69.00? http://www.weisd.com/store2/PTS9-160-05.php
That's way too much for me!I only paid $10 for the set and i consider it in "cosmetically challenged" condition. All i need is the value of a resistor and that would probably fix it.....
Old 04-30-2012, 07:26 PM
mrflex65's Avatar
You will be able to get a picture by just touching the center conductor of the coax to either of the VHF antenna screws. It may be a little snowy, but it will let you see something.
Now, why didn't i think of that?
Old 04-30-2012, 07:27 PM
Here is the set up on the back of my System 3. I thought they all had this set up, but I could me mistaken... On mine.. see the black wire? If you plug it into the hole, you use the screws for antenna input, if you pull it out, you can use the "normal" cable feed.
Old 04-30-2012, 07:35 PM
mrflex65's Avatar
Thank you very much for your kindness!The one i'll most likely really need though would be the 9-151 module since they were busy prying off shields on it for some odd reason. If you come across one cheap, please let me know!
Old 04-30-2012, 07:40 PM
mrflex65's Avatar
Mines totally different.....
Old 04-30-2012, 07:44 PM
Old 04-30-2012, 08:01 PM
mrflex65's Avatar
Are you sure about R3201? I found a service manual for a 9-160-3, and there is no R3201. If it's connected to the E of the HOT, then it could be L3302.
Well, originally this board was a 9-160-3 but now it's a 9-160-5! R3201 is right below L3302(right below the number 28) which is a .18 ohm 3 watt resistor.Whatever R3201 was is still a mystery to me....
Sorry about the blurry pics....
Old 04-30-2012, 08:45 PM
well.. They used a sub, which according to my Zenith module guide IS correct. A 9-160-05 would sub for a 9-160-03, and obviously there would be mods for the sub module. Somebody has got to have a 9-160-03 laying around.. hopefully! I was sure I did and now am wondering why the hell I have so many Chromacolor 2 modules......
As I dug into my old parts stash.. the show "Horders" popped into my head. LOL!
Old 04-30-2012, 09:30 PM
mrflex65's Avatar
These may help.
Sorry about the quality, it seems that the server resized them after I uploaded them. If you can't read it, I can email it to you.
If you don't mind?
I think i deciphered part of it.
One leg of LX3353 (width control) goes through E3521 and then through R3252?(1k 1/2 w) to ground?Maybe R3252 is R3201 on the -05 version?
Old 04-30-2012, 09:43 PM
mrflex65's Avatar
I use to be into "hoarding" about 25,30 yrs. ago,but it was "all" vacuum tube stereo and tv equipment including huge boxes of tube "spares"....
Old 05-01-2012, 12:09 PM
