Old 01-18-2012, 12:10 PM
Wharfcreek Wharfcreek is offline
Help Needed - perhaps in wrong forum?
Hello VK,
New guy here! Been an AK member for a while, but have absolutely ZERO radio experience or knowledge.
Here's my dilemma: I purchased an old antique radio this past weekend as a 'late' Holiday gift for my Brother and Sister-in-Law. Craigslist purchase, paid $60, so not a huge problem if this ends up being a lost cause. Anyway, this unit 'looks' very similar to some of the old Grundig radios I've seen in the past, only it's made by a different company: EMUD, or Ernst Mastling ULM.D. It appears as if it's a model T-7.
Anyway.....got it home and have been bringing it up on the variac over the past day. It's at about 100 vac now.....and I've determined that the audio circuit is working. I can hear some 'scratching' when I wiggle some tubes, but more to the point, I can push the 'phono' button input selector and touch a screw in the back that is presumably the phono input hot connector and I get a good ac hum! There is also a 'tape' button, and the adjacent screw produces hum in that position albeit a bit lower in intensity....again presumably due to this being a lessor sensitive input.
So....this background being stated, I am getting ZERO RF through this thing! I have 3 bands: AM, FM, and SW and NONE of them produce so much as a glint of signal. There is a stick antenna and an FM Loop antenna...both hooked up and appearing to in good shape. But, I don't get the typical am buzz, no hiss in SW, and basically NOTHING in any position.
At this point, I'm 3 days away from traveling to Michigan where I plan to meet my brother and SIL and, hopefully, give them this functional radio. I might mention that it IS German....as is my Sister-in-Law....so the point of this gift was to bring a bit of acknowledgement of her past culture and roots into my consideration when adding to the bulk of Holiday gifts!
If I should be in the "Tech" forum, then I trust the moderator of this forum will move me. But, I'm hoping that perhaps a 'vintage' radio guy will have a clue where my problem might lie and be able to steer me there in a simplistic manner. Keeping my fingers crossed.
Thanks VK!!
Tom D.
Old 01-18-2012, 12:32 PM
Reece's Avatar
Reece Reece is offline
Old radios should really be gone through electrically and old capacitors replaced at least as parts that are 40 or 50 years old can fail at any time. However, with the radio on, try cycling the bandswitch buttons on and off a dozen times. The contacts are probably dirty. If you can get to the switch, spray cleaner into it while working the buttons. The other thing to do is check the IF and RF tubes in the set, at least to see if they all light. Spray cleaner on the tube pins and plug in and out of socket several times while the pins are wet to clean the contacts.
Reece
Old 01-18-2012, 03:34 PM
bob91343 bob91343 is offline
Emud was a popular name last century. So the radio is probably a decent one. I wish I could offer a suggestion but with the short time you have available it would take too long to get you going.
Old 01-18-2012, 04:41 PM
Hey Bob and Reece,
Thanks for responding so quickly. I know 'time' is an issue here......and I may just pack up the radio and take it with me in it's present state, and then work on it some while in Michigan. We'll see.......I may just trade it for a fountain pen and give that to my Brother ....ho ho ho!
From what I can see.....all the tubes do light up. I have cycled through the switches several times.....and I don't get so much as a pop or thud on the audible side when the switches are being pushed. But....like I said.....I can push the 'phono' button and then touch the screw head in the back of the unit marked 'phono' and I'll get a good hum from the speaker. Same when hitting the 'tape' button.....only a reduction in gain, presumably at the input itself.....or a matter of sensitivity differential between the Tape and Phono inputs. However, in both cases, it's evident that the audio amplification section is functioning.....so at least I know that much. But, again, when selecting ANY radio band......no noise whatsoever. I did jiggle tubes a bit, and still not static or change in condition. All tubes appear 'lit' EXCEPT the 'tuning eye' tube that is part of the front panel....and something that I seem to recall would illuminate with a blue or orange glow....either more or less brightly according to signal strength. I can't see the number on this bulb.....it appears to be a Telefunkin of some kind......but it's doing nothing from a functional standpoint that I can see. One other comment...the two dial lamps were a bit oxidized and inop when I first started, but now they both illuminate fine. The rubber grommets that held them into the panel both disintegrated when I move the bulbs.....but the lights themselves seem fine. So....that's an indicator of continuity, corrosion, and available voltage.
I guess maybe I've made some progress in diagnosing this thing....but I fear that the next real step may be actually removing the chassis from the box....and that does NOT look easy. I may just have to wait until I get to Michigan to attempt that. But, for now....any further suggestions are welcome....and again, thanks for the comments thus far.
Tom
Old 01-18-2012, 05:57 PM
It's time to take a closer look. You need to measure the plate voltages on the tubes involved with receiving radio signals. There is a local oscillator that needs to be oscillating. There is one, maybe two, stages of IF amplification, and a detector of some sort.
The tuning eye tube is of no consequence. Deal with it once you get the radio working. The fact that it's not glowing implies loss of B+ voltage to part of the set. So you may have an open dropping resistor.
Old 01-18-2012, 06:47 PM
Tuning eye was glowing......I just couldn't see it in the afternoon light and with the voltage still at less than full level. But, once sun went down I could see both the glow in the tube from behind the set, as well as the green view of the tuning section. I guess I'll have to look up all the tubes to see what their function is, then get back w/ a report after voltages are taken. TSD
Old 01-19-2012, 12:21 PM
teevee's Avatar
teevee teevee is offline
One of the common failures on these sets is loss of screen voltage in the IF's, the bypass cap shorts and takes out the screen dropping resistor (Usually a 1K resistor)
Also, I routinely replace the coupling cap to the last audio, It's one of the areas where a little leakage causes grief. Oh yes, the tuning eye being very weak is also common.
Old 01-19-2012, 01:08 PM
TV, Thanks for the info. I've clearly got WAY too much to learn about radios to be into this one at this time. Honestly......while I know a 'screen' as it applies to an audio tube.....I'm not sure how they relate to IFs in the radio world. So, I clearly need to go back to square one and do some study work. I'm pretty sure it takes YEARS to become proficient in radio repair......but maybe I can find a local 'mentor' who can school me a bit. I give AK a LOT of credit, as it's members have helped me greatly with my quest to learn about audio amplification. But, AF and RF are significantly different enough that I've stayed away from radio for all these years.
Anyway...........I do plan to pull the chassis and, I guess....just see what I see! I'll keep you all posted on my progress....if any! Again, many thanks!! Tom D.
Old 01-19-2012, 06:08 PM
It is not all that hard to learn to fix the simple stuff in most radios. As time goes by we get better and learn to trouble shoot the tough sets and grow as techs.
Old 01-19-2012, 07:44 PM
Hey Tom,
I appreciate the 'semi' pep-talk. The concept of 'time goes by' is one that is somewhat painful to me at the moment......3 days away from hitting 60! Not too sure how much 'time' I've got left......but, hopefully another decade or two. Just finished performing surgery on a wireless house phone......had a bad one w/ a good display, and a good one w/ a bad display. Trying to remove those hair-like LCD contact from micro-traces on the board while hands were somewhat shaky...well, just confirmed my suspicion that I'm not getting any younger! But, the successful operation helped retain my meager level of confidence. I really WOULD like to fix this radio......not just to present it to my brother and his wife as their 'late' holiday gift, but also to gain the learning experience. It does seem weird to me that the whole RF section would be dead.....all 3 bands. That seems to me like it should be something 'simple'.....like a switch or wire or contact.....or maybe that screen voltage previously mentioned. I am leaving Sunday for Michigan......and this radio is going with me. I'll be there for a week....and hopefully I'll get to the bottom of the problem before I leave....and can then 'gift' it to my brother and his wife. I'll have a pc there....and trust me.....I'll be back on this forum w/ up-dates and further question!! Thanks again Tom! REgards, Tom D.
Old 01-19-2012, 08:57 PM
You are almost 60?! Wow that's pretty old to be getting into electronics. I do repair work for fun and have a well equipped lab. But 60? No way! Actually, this summer I will be 80 years old. Been a ham since 1949.
Age is a state of mind. I'm also a weight lifter and jazz musician. Who cares about my age (except the young ladies)?
Old 01-19-2012, 09:22 PM
Bob, not anywhere close to Detroit, R ya?.....or anywhere close to the Pennsylvania or Ohio Turnpikes? I'd give my eye tooth to come meet ya, shake your paw, and have you look at this elderly radio............. TSD PS..... 80 eh? Well...... you give me strength!! Wish I'd started w/ HAM stuff when I was a kid. But, like I said....though new to the hobby....perhaps I can still learn....in time!! Tom D.
Old 01-19-2012, 10:09 PM
Tom, the day you stop learning is the day you might as well die. I am always learning, never so smug as to feel I know it all.
I am fairly close to you, but that also is a state of mind. I am actually in Los Angeles. "The land of orange juice, sunshine, and beautiful women."
Old 01-20-2012, 09:38 AM
maxhifi's Avatar
maxhifi maxhifi is offline
Don't be intimidated by this stuff. What you need are some books on radio to start learning some of the lingo and get some background info. Buy or download and print out an RCA tube manual from the 50s or 60s, and read the front section. It's not very long, and you'll learn a lot about common circuits. Then, take a look at the back, and study the circuits section. I learned a lot from mine, the pages went from white to a dull grey in the first 5 years I owned it.
Old 01-20-2012, 10:20 AM
Hello Max,
Thanks for your comments. Good advice! I do believe that some years ago I did have that manual.....but seems to me that about 4 or 5 pages in I was so lost that I put the book aside.....again intimidated by the seemingly insurmountable of digesting what was contained within. In later years, and resulting from my love affair with guitars and amplifiers.......and accumulating a collection of old guitar amps in need of repair that shop prices prohibited me from doing anywhere other than at home myself....I ended up buying some of the more popular publications on guitar amp repair. After a couple of years of fumbling through all that, I got to where I could re-cap a power supply, 'tweak' a front end, replace a power or output transformer, and perform basic trouble shooting for simple repairs. About that time I made a decision to re-locate my home....sold off almost all the guitars and amps to help fund a new house....and basically got 'out' of that hobby. Then, about 3 years ago I took up tube amps in home audio thanks to the acquisition of a Dynaco ST-70. Again, my urge to take soldering iron in hand led to what is now a small collection of tube home audio amps of both separate and integrated types. Most have been acquired either broken or dysfunctional, so I give myself some credit for being at least modestly capable in that area. BUT......Radio?......to me, that's another whole area into and of itself! I'm sure there are some basic similarities.....but such can be said for many a comparison.....a canoe to a yacht, a glider to a Jet, a VW to Porsche, etc! And, I do believe that the whole concept of 'radio' involves technology that is completely unrelated to 'audio' in that the signal has to be 'detected' prior to amplification vs 'provided' in the form of a source like a record, tape, microphone, etc. So, this radio project really does have me intimidated! I'd give my eye tooth to have a local mentor.....although I can't express how grateful I am for this place!! AK has been a tremendous resource to me in working through issues on the audio amplification front....and I'm sure VK will provide the same. Anyway.....I prattle on! Sorry!! Again, thanks for the advice! Tom
