Old 11-13-2011, 11:07 AM
stusnyder's Avatar
Ge 802
Dug this chassis out last night, it has been totally recapped, some resistors replaced. It has a raster, but no picture. I used a B&K television analyst and injected video at the v14 video amp tube. I got no test pattern but I did get some kind of signal thru, because the rastor changed state. Any suggestions where to look next?? This is one set I'd really like to get finished.
Old 11-13-2011, 11:26 AM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
Try injecting a signal at the picture tube where the video amplifier connects. If you get a picture then the trouble is in the video output circuit. It should not be too difficult to isolate provided you are injecting the right kind of signal. That is pure video, not RF.
Old 11-13-2011, 03:52 PM
vts1134's Avatar
vts1134 vts1134 is offline
Looking For Time
Good luck with the 802. I'd love to see a photo when you get a picture. I'm really fond of the the look of the sister set to yours, the 801.
Old 11-13-2011, 07:40 PM
stusnyder's Avatar
Anybody know what pin on the crt?
Old 11-13-2011, 08:12 PM
David Roper's Avatar
console lover
The video is cathode modulated--through a .1 mfd cap. Cathode is pin 11.
tvontheporch.com
Old 11-14-2011, 10:08 PM
stusnyder's Avatar
I injected video at the terminal strip where the wire from the crt pin 11 connects...only get horizonal lines. So I disconnected the wire and tried it directly to the crt, then I loose raster all together.
Old 11-15-2011, 01:29 AM
leadlike's Avatar
leadlike leadlike is offline
When I worked on my 802, I had the same issues-I think a mica cap went bad inside that awful tuner, and killed signal input. Anyway, injecting video in the same manner you did, I only got horizontal lines. Injecting video at the video amp really messes up the horizontal frequency. Adjust the coarse horizontal control (You'll need a plastic diddle stick for this, I ground down a chopstick to fit, as a screwdriver throws off the frequency more) until a picture pulls in. Hope that helps!
Old 11-15-2011, 05:06 AM
stusnyder's Avatar
The problem is similar as you explained, although I got a feeling there probley more wrong with it. If I inject sync signal, I get the black horizontal lines that are shown in my B&K user manual.
Funny I usually play a trf radio when I'm down there working and usually get all kinds of squeeling noises out of the radio when I mess with the tv chassis.
I'll make up a non-metal screwdriver tonight and see what that brings.
Old 11-15-2011, 10:17 PM
stusnyder's Avatar
Got somewhat of a picture, as you can see, the horizontal has interference in it. Vertical locks good. Don't got much contrast control. Any sugestions where to go next?
Old 11-16-2011, 04:12 AM
leadlike's Avatar
You won't have any contrast control. On this set, the contrast control raises and lowers the plate voltages on the tubes in the IF string. Since you've bypassed all that, twisting the contrast control will have no effect.
Try to inject a signal from a DVD player next. My BK 1077 produced odd results like that on my 802 project, while the video from my DVD worked fine.
Old 11-16-2011, 10:34 AM
kvflyer kvflyer is offline
Got somewhat of a picture, as you can see, the horizontal has interference in it...
Could that be a bad capacitor in the yoke? They often have mica caps inside of the yoke. I don't have a schematic in front of me so I may be way off base...
Old 11-16-2011, 01:25 PM
stusnyder's Avatar
Tried that, did not get any results. Might not had it hooked up correctly? I set up the 1077 for IF and it seems I'm getting something thru the IF stages to the video detector. Still got that blasted white vertical line though...
Not much left in there for stock components. All the mica's and a few resistors are still original. Getting something thru the tuner Rf-wise but not like it should be.
Old 11-19-2011, 09:14 AM
stusnyder's Avatar
making progress
Making some progress
Old 11-19-2011, 09:56 AM
I would say you are!
Old 11-19-2011, 10:19 AM
stusnyder's Avatar
Thats video injected at the v15b tube dc restorer which is a 6h6.
I have to go thru the IF stages next.
