Old 09-05-2011, 02:55 PM
Yeah if the base were intact that would be true. But there looks to be a BIG chunk broken out and missing, and the resultant gap rather sloppily filled in with epoxy. 'Least that's the way it appears to my enfeebled eyeballs.
Yes, indeed there is a big chunk of base missing and the epoxy was slopped in. I did some more work on the set and have a better picture. So, for now I'll just leave the old CRT in there.
Originally Posted by Zenith26kc20 View Post
I noticed that your Admiral in one of the pictures has the picture off center. Mine is like that too. My focus/centering coil is all the way and, it will fill the screen but still is off to the left. Are you able to get decent centering or is this a trait of these TV's?
Yes, I have a pretty good centering range with the lever. The horizontal centering is also effected by the hor. drive, hor. lock and hor. sync.
I found a few out of spec resistors in the hor. oscillator circuit and just replaced them all. That threw the oscillator off a bit so I went through the adjustment instructions in the service manual. When I finished with all that, here's what I got. The horizontal linearity isn't perfect, but overall not too bad I think.
First picture is from my Leader LCG-400, then a local low power OTA VHF transmission. Last two are from a converter box.
Originally Posted by Red Raster View Post
What a nice clean chasis and what luck my 12X1 looks the same.
Not so clean topside This set came from Florida and I suspect the humid air contributed to this rust. I'm going to tackle it with some naval jelly then paint the worst areas to keep it at bay.
Old 09-07-2011, 10:26 PM
After some chipping with a knife, a whole lot of filing and a little vaseline, I finally got it out
Now I can really get in there and clean the chassis. I'm also going to try a different CRT that has a better cutoff.
Old 09-13-2011, 05:49 PM
I'm slowly winning the rust battle. I'm doing a section at a time. Once the rust is dissolved, I'm left with deeply pitted steel. I've been painting that with Rustoleum "rusty metal primer" then aluminum paint. I think it's a little cheesy looking, but should keep the rust at bay.
I find it lurking everywhere!
While waiting for the rust to dissolve, I've been checking everything else including the tubes. Most were good, a few marginal and this nearly dead 6J6.
Shorts, leakage and nearly no emission.
I find it amazing that this set is functional with this RF oscillator/mixer tube installed in the tuner.
Of course it works even better with a good tube
Old 09-13-2011, 07:14 PM
Glenz75's Avatar
Glenz75 Glenz75 is offline
NZ Vintage TV Collector
Is amazing how some sets can function with half dead or nearly dead tubes! Like that Telerad oddball set that I'm still working on, virtually all of the 6SA7's had little or no emisson but the TV still seemed to work! Weird huh?
BTW I was rather impressed at those upclose shots of that CRT, such a sharp image and good definition too, not bad for a weak picture tube, I can only imagine what a good CRT will perform like...
Cheers Glen
Visit my Vintage TV & Radio Page - http://nzvintagetvradio.blogspot.com/
My YouTube Link - http://www.youtube.com/user/glenz1975?feature=mhsn
Old 09-13-2011, 08:09 PM
classicradios's Avatar
classicradios classicradios is offline
Nice work on that chassis! I don't envy the corrosion battle, My chassis only needed the dust cleaned off.
image.php?u=360&type=sigpic&dateline=1196226370
Old 11-17-2011, 09:31 PM
Originally Posted by Nuke View Post
I gotta get a bakelite tv. That's on my keep my eyes peeled for list. I like the way they look.
I just noticed you posted in my 20X11 thread that you have a couple now. That was quick
Old 11-17-2011, 09:42 PM
Nuke Nuke is offline
Actually I have one and a cabinet that is floating right now. I am getting a HV cage from grimer so I can jump back on it. I will be looking at some leftover chassis from a tv shop that closed in the 60s either this or next weekend, that should be fun. Maybe I'll find the guts for it. BTW your videos are a big help. There is no way I'd ever get these running without the internet.
