Old 08-20-2011, 10:33 AM
vts1134's Avatar
vts1134 vts1134 is offline
Looking For Time
Rather than just ask whether to go higher or lower in value on R65, can some one tell me what R65's purpose is without telling me higher or lower?
Old 08-20-2011, 10:45 AM
Well, note that it's in series with the 1 meg. vert.hold control. And also the .0047 cap (C48) forms a time constant in combination with R65 and the v.hold control. Ie., lower resistance = cap charges quicker. Higher resistance = cap charges slower. So if the oscillator is running too slow for the vert.hold to correct it, which way would you want to go with R65's value?
Old 08-20-2011, 05:31 PM
vts1134's Avatar
Looking For Time
Lower. Thanks for not giving it away too much.
http://www.youtube.com/watch?v=yU6BfOV4_fc
Pay no attention to the massive explosion at :14, they are filming Batman directly outside of my window.
Still much work to be done!
Old 08-20-2011, 06:47 PM
Yay!! What a difference one little part can make.
Phil Nelson
Old 08-20-2011, 07:09 PM
Well done, Mr. Dragonslayer! I gotta congradulate you on your tenacity and perseverance. That set started out with multiple and disparate problems, and contains some novel/'oddball' pre-standardization circuit fratures. It would have been a signifigant challenge even for a seasoned techie. She's definitely on the home stretch now.
Was that the Batmobile backfiring outside?
Old 08-20-2011, 07:48 PM
vts1134's Avatar
Looking For Time
It was a tumbler getting blown up.
Old 08-20-2011, 08:03 PM
Hmm.. seems to be a vid of it here (after the #!@$%^&* commercial) -
http://www.wpxi.com/video/28907146/index.html
But still trying to figger out what a tumbler is.
Old 08-23-2011, 01:05 PM
vts1134's Avatar
Looking For Time
Home Stretch it is!
After much adjustment of front and rear controls I've got is as linear as I could. A couple notes: the sound is terrible, I have to turn the set up much too loud to hear anything. The video below shows what happens to the picture when I adjust the contrast control. The video starts with the contrast cranked all the way up then some adjusting from all the way up to all the way down a few times.
http://www.youtube.com/watch?v=jVzPM6IlFeE
One other thing I've noticed is that the picture isn't level, it slopes from left to right. Is there an adjustment for that, or is it a symptom of another problem?
Old 08-23-2011, 05:01 PM
Home Stretch it is!
WooHoo! Is that cool or what.
The bending when you turn up the contrast is related to the rather primitive sync take off scheme; it picks the sync off after the contrast control, after the video output stage in fact. Bending and "flagging" with an overly strong signal or high contrast is generally just part of the charm of such early designs. Does it straighten up if you reduce the signal strength at the antenna input?
To level the picture you rotate the yoke. There has to be something to loosen so the yoke can turn, then you tighten it again.
On the low sound, have you replaced C4, the little 4 mfd electrolytic that connects to pin 2 of V9 (the 6T8 tube)?
Old 08-23-2011, 08:11 PM
vts1134's Avatar
Looking For Time
The bending when you turn up the contrast is related to the rather primitive sync take off scheme; it picks the sync off after the contrast control, after the video output stage in fact. Bending and "flagging" with an overly strong signal or high contrast is generally just part of the charm of such early designs. Does it straighten up if you reduce the signal strength at the antenna input? (the 6T8 tube)?
Thank you. That was all I needed to know because my set was flagging when the contrast was turned down. Something was backwards! M5 was backwards, eureka! I installed M5 correctly and made some adjustments and got what you see in the video below.
http://www.youtube.com/watch?v=CgN4siWzFGo
We are so very very close to.
Just some audio tweaking and getting rid of retrace lines to go.
Old 08-23-2011, 08:30 PM
VintagePC's Avatar
Tube bug got me 05/2010
Congrats! Almost there!
(BTW, I was listening to Let me hear you scream by Ozzy while I was watching that video... made for an interesting combo, and fit creepily well at times.)
Old 08-23-2011, 08:31 PM
Lookin' goooood. Yeah, you always gotta watch the polarity of diodes. The banded end denotes the cathode. That's universal practice AFAIK.
The retrace lines may go away at lower brightness setting. There doesn't appear to be any retrace blanking. Another 'charm' of some early sets.
Old 08-23-2011, 08:36 PM
vts1134's Avatar
Looking For Time
If there's no retrace blanking then it's damn near done. Just a bit of audio performance to go.
Old 08-24-2011, 01:03 AM
Just a passing thought-- if you go to tweak the audio adjustments, whatever you do, don't touch any of the video IFs. The video IF alignment looks really good. Fine detail in the pic looks good, with no ringing or smearing which would indicate alignment was off.
Old 08-24-2011, 02:35 AM
If you're going to chance tweaking the audio IF "by ear," without following the factory procedure, you can make a little flag of tape for your screwdriver handle. Note which way it points when you begin, and then count how many half turns (or whatever) you go in a given direction. That way, if your adjustment makes no difference, or it makes things worse, you have a way back to Kansas.
Phil Nelson
