Old 07-17-2011, 08:34 PM
Admiral Color Adapter.
I had always though those Color Adapter sockets seen on some models of early 50's sets was to allow for use of a color wheel on an existing B&W set, according to this it was to allow your existing B&W set to receive Color Broadcasts (in B&W) if the CBS Color standard had been adopted.
That explanation makes a lot more sense.
In any case this has to be a very rare item!
http://cgi.ebay.com/Antique-TV-Admir...item4cf8b3dc94
Old 07-17-2011, 08:54 PM
miniman82's Avatar
First Light: 1952-2011
Nice, I hope Steve McVoy bids on this and wins!
Evolution...
Old 07-17-2011, 09:50 PM
David Roper's Avatar
console lover
Apparently this gadget was designed to be used with or without a color wheel (you just wouldn't get color without the wheel).
tvontheporch.com
Old 07-17-2011, 10:04 PM
Gosh, I hope Admiral didn't make up too many of those. I suppose that most went in the dumpster. It's pretty amazing how this one escaped.
Old 07-17-2011, 10:17 PM
Arrgh, sorry David, I think I edited your post instead of Quoting it, I don't seem to be able to reverse it, hopefully I didn't lose anything.
Anyhow what I meant to say was:
From what I get after reading the description existing B&W sets would not have been able to receive the incompatible CBS color broadcasts so some manufacturers made sets with the option for a plug in adapter so they wouldn't be obsolete.
They would still have been B&W but able to pick up the color shows in B&W, which the RCA compatible system allowed without any adapters or modifications needed.
Old 07-17-2011, 10:25 PM
If someone here gets this they'll need to find a compatible Admiral model, lot's of them around I think, feed it a show using a CBS Color signal and see how well it converts it to NTSC B&W!
This really is something that need to wind up at the ETF!
Old 07-17-2011, 11:01 PM
console lover
I think that's what I wrote. That's all I can remember writing anyway.
The difference between the B&W standard and the CBS color standard was mainly this: receivers made for the former were incompatible with the latter due to a difference in scan rates. ISTR a distinction being drawn between *adapters*--which allowed color broadcasts to be received in black & white and *converters*--which provided for connection to a color wheel.
The gadget in the auction is referred to as an adapter-converter. Notice it has a three-position switch--standard, b&w-from-color, and color. From what I understand the image size had to be reduced for use with a wheel on larger screen sets. So the second switch position would allow you to watch a CBS show full screen--in black & white--and the third position would shrink the raster to fit a wheel.
In either case the device only changed scan rates of the receiver, it didn't actually convert CBS to NTSC.
tvontheporch.com
Old 07-17-2011, 11:12 PM
I see, a little less exciting then I suppose, still rare though.
I have a Wilcox-Gay branded Majestic that has a color jack on the back but I think it's only three pins and not an Octal plug, it is wired into the chassis however.
Old 07-18-2011, 06:52 AM
earlyfilm's Avatar
Eternal Member
From the consumer instructions in the 7th auction photo:
"In addition to the standard black and white pictures which it originally received, your set is now equipped to receive black and white pictures from TV * color signals, or color pictures if a color wheel is used."
* Meaning the 441 line CBS 24x3i color signal (or 72i B&W), but not the still not invented in 1951, NTSC color signal.
Old 07-18-2011, 05:29 PM
Steve D.'s Avatar
Steve D. Steve D. is offline
One of several Admiral 1951 ads touting "Color TV Optional", I assume this ment the Admiral color converter in the e-bay auction.
http://imageserver.lib.duke.edu/dc/i...ed/TV0008.jpeg
Probably saw color on this bar equipped model with out the color converter. Lol: http://imageserver.lib.duke.edu/dc/i...ed/TV0014.jpeg
-Steve D.
