Old 06-16-2011, 07:35 PM
miniman82's Avatar
First Light: 1952-2011
the only way I can get a dim raster is to turn the brightness all the way up, the only screen control allthe way down, and the drives all the way up.
Shouldn't the screen controls be up as well? If you reduce the screens, the guns will emit less electrons and of course it will be dim. Are drives the same as background?
The drive controls are where the sparking is coming from.
Bad pots?
Evolution...
Old 06-20-2011, 01:43 PM
I'm sure it does work that way, but I never really understood the attraction of that arrangement. The few times I've used TVs with that type of remote, I found them useless and frustrating. The volume steps were never right, and it was annoying to have to go through 12 channels to get back to the previous one. I know the technology only allowed for a limited number of functions on the remote. I just find it interesting how they allocated them. I would love an RCA set with one of the more full featured remotes.
Some '60s Zenith color TV remotes (Space Command 600 or 600x; I'm not sure) were set up so that the volume up/down buttons did double duty as the tint and color controls. The latter functions became active when the mute button was pressed; Zenith reminded the user of this with the line at the top of the remote button panel: "Adjust color and tint after pressing mute." I'm not sure whether the channel up/down buttons were used for alternate functions.
Zenith's first wireless electronic remote control TVs used the SC-100 one-button remote. The single button simply changed channels in one direction and could turn the set off when the tuner reached an unused channel. This system likely unnerved some viewers if they overshot the channel they wanted to watch; this meant having to hold the button down while the set's tuner clunked through 13 channels (counting the UHF position, if this series had one). The advent several years later of random-access tuning, using 10 buttons on the set and/or on the remote, now standard on all TVs, solved this problem, as now the viewer could select the desired channel, and go instantly from one local station to the next, without having to see five to twelve channels (depending on how many local channels the viewer's area had) of nothing but snow in between.
Old 06-20-2011, 10:06 PM
That is exactly how I remember the hospital TV worked that I used in 1968, but it was a wired remote control. Like many cable-TV systems, the hospital had some UHF stations translated into the unused local VHF channels, and the UHF position on the TV was "power off". Yep, if I passed the channel I wanted, I had to go all the way around again, including turning the TV off and back on in the process.
In the late 70's, the Olson Electronics store in Chicago had a surplus add-on motor for TV tuners for sale for maybe $5, and it included a power switch in its presumed-UHF position as well.
Old 06-27-2011, 06:56 PM
Well the sam's arrived from banderson today (thanks!), and it definitly uses a wierd CRT set up procedure(compared to the Zeniths and RCA clones I'm used to) the cathode levels are set by pluging the wires that come from the socket into several terminals rather than by potentiometers. The RGB background controls(miniman had the name right first) adjust the grid bias, and a single "master screen" controls the the three screens the leads of which are conected together just after leaveing the socket.
When I get the chance I'll attempt the grayscale procedure, and see if I can get a good picture.
