Old 03-11-2011, 11:11 AM
turned it on this am, came right on.
Got the rifleman on now (B&W), grey scale looks very nice. These set's make a very nice pic.
Old 03-11-2011, 11:17 AM
Just curious, I see on the regulator board the warning about not fixing but replacing. Anybody know what the deal was with that?, I dont see any parts that look special, unless there is something special about some of the transisotors. I did not look to see the PN's on them.
Old 03-11-2011, 12:11 PM
Old 03-11-2011, 12:22 PM
Gunslinger Gunslinger is offline
critical 32 volt regulator
Old 03-11-2011, 01:13 PM
airgrabber-6's Avatar
airgrabber-6 airgrabber-6 is offline
Avoiding electrocution.
Are you still planning to deliver it back to the original owner?
current victim:
"Blondie"...a '62 Magnavox 27" Normandy Provincial
Old 03-11-2011, 01:17 PM
They dont want it, just glad it went to a good home. I wish they would as I dont have room for it as is.
I tested the voltages
27=26.73
22=22.08
11.8=12.38
there was a 210 but it tested at 20.92 so maybe that was a 21, maybe I was misreading the board.
on a different board I found another 210 it was 200vdc
Old 03-11-2011, 01:19 PM
I am truely not a fan of the cab style, so maybe a good one to try out my wood working skills on. I have a few others in need of wood work, this could be a test case. I would just make a ply box, fit the front in, laminate some veener to it and add some screw on legs.
Its too bad no one is interested in this era, like I said before it rivals any pic I have seen.
Old 03-11-2011, 01:43 PM
ok maybe a dumb question, but am I suppose to be able to a door behind the tuner knob to setup the tuner? I can't seem to see if there is a latch or something. I will get a close up pic of the front later.
Old 03-11-2011, 01:52 PM
rcaman's Avatar
rcaman rcaman is offline
you lost drive to the output and that is what shorted it. i used to just solder the legs of the output to the socket it sits in the base and emitter. that would sole the problem the majority of the time 90%. steve btw i sold a lot of those sets. this was good chassis
Old 03-11-2011, 02:16 PM
Here is a pic of the front
Old 03-11-2011, 03:34 PM
sampson159's Avatar
sampson159
is crt good?cant tell from pic.these were decent sets.certainly not rca s best,but good for the times.
Old 03-11-2011, 03:44 PM
On some of those sets, you turn the RCA logo to unlatch the door.
Old 03-11-2011, 03:50 PM
Nice picture on that set!
current victim:
Old 03-11-2011, 03:51 PM
it did not test well but aside from that I makes a very good pic, looks better than the screen shots. Its a bit reddish (like the screen is too high) for the 1st few seconds, but by say 30 seconds after it comes up its fine.
I like the idea of soldering the HOT in place. Kinda scary from the stand point of ever having to remove it, but I can see how that could be a real problem area esp if its not used a lot (slight corrosion causing lack of good connection at the pins).
I will prob pull the chassis one more time and clean all the module pins, solder that HOT in and call it done. Its been coming right on with no issue, and running for hours with out a hint of a problem.
The only thing that is odd is the horz control, very sensitive, you can flop it one way and then the other with just a turn of maybe 5 degrees, but once its locked in the stays locked. On my other sets you can move the horz adj a lot before losing sync.
I have a lot of more interesting sets I need to get to work on so I dont want to spend too much more time on this. I hope to just button it up, maybe do a minor bit of clean up, then stow it until I can find a home for it.
Old 03-11-2011, 04:10 PM
Bingo
