Old 08-20-2010, 10:11 AM
RCA roundie
picked up local today, VERY ruff, but for 30$ figured I would gamble on the CRT being ok. looks like a CTC-7 (they have the vert chassis right?) in a metal cabinet. All rusty blah blah blah.
Looks to be pretty much all there from 1st glance, convergence yoke looks goofed up some, but the neck on the crt is there and the socket looks to be unbroken.
I will put some loose juice on the socket to loosen it up and test later.
Old 08-20-2010, 12:30 PM
JB5pro JB5pro is offline
I wonder if we will ever see it?
Old 08-20-2010, 12:34 PM
yea I will post some pics later, its in the back of the truck now.
Old 08-20-2010, 12:45 PM
pics.
tube is a sylvania
Old 08-20-2010, 12:49 PM
crt socket was stuck so I just sprayed it down, will try later ot see if I can get ot off to test the tube.
Old 08-20-2010, 12:59 PM
miniman82's Avatar
First Light: 1952-2011
Looks like the same chassis my '9 has...
Evolution...
Old 08-20-2010, 01:07 PM
That is a CTC 9, notice that the power transformer does not have the two rectifier tubes. This is the Boswell model. Nice set, especially for thirty bucks! That thing will clean up nicer than you think. I hope the CRT is good, even if not it was worth every penny.
Old 08-20-2010, 02:42 PM
Frack, red gun filament not lighting up. B and G are fine with good emissions and cut off.
oh well, guess it become a dud for some future rebuild if that ever become possible. I will hang on to the chassis in case I ever come into a CRT.
Old 08-20-2010, 03:09 PM
I can see the filament leads are both intact, but I can tell how they hook up I assume there is a weld that ties all of them together. I tried tapping the neck to see if there was a loose connection but nothing.
Old 08-20-2010, 03:17 PM
miniman82's Avatar
Quick, send it to Scotty!
Evolution...
Old 08-20-2010, 03:19 PM
called left a message to see if he was still accepting work
Old 08-20-2010, 05:01 PM
pulled the chassis, not too bad but pretty rusty. The fly did not appear to be cooked. removed the CRT and glass, rinsed out all the rust and loose carp inside. Its drying now. I may remove the mask, and then put all the rest up in the attic. the heat would be hard on the mask.
I will prob end up going over the chassis and testing it with the dead red gun CRT. I can at least get it running and will have a good chassis.
Oh well at lest the yoke checked out.
Old 08-20-2010, 10:08 PM
One of my 21FJP22's had a dead filament; careful tapping with a screwdriver handle eventually brought it to life, and it has been reliable so far.
Old 08-21-2010, 08:05 AM
well there is hope then, I will give that a try
Old 08-21-2010, 09:56 AM
