Old 07-16-2010, 10:10 PM
Eico 315
While waiting for the tantalum capacitors for my Leader, I decided to give my EICO 315 a look over. I've fired it up a couple times before and there's something wrong with it. As I rotate the dial, the output will die at some point. I just checked all the tube and they're fine. I think I'll swap out those paper caps next.
Old 07-18-2010, 05:09 PM
Findm-Keepm's Avatar
Followin' the Rules...
Check the integrity of the variable cap - the brass spring and ball bearings in my 324 caused the output to come and go - if I pressed slightly inward on the knob, things were okay. A good cleaning of the variable cap fixed it. Definitely change the ol' caps though - waxy caps gotta go!
Cheers,
Brian
USN RET 22YRS (Avionics/Cal)
Old 07-30-2010, 08:39 PM
Cheers,
I finished the recap and cleaned the variable cap contacts. It's working fine on the lower bands A, B, C, and D, but I'm still having problems on bands E, F, G. The oscillations die on the left 1/3 of the tuning dial
The tubes check good and I've swapped them with known good tubes for the heck of it - no change.
All the resistors measure 10-20 % high, but I figure that's OK. I'll check the coils and trimmer caps next I guess.
