Old 12-08-2009, 08:34 PM
freakaftr8's Avatar
Convergence freak!
Oh yours is a B&W model right? I think I remeber that chassis being like that, mine harnesses together all by white connectors.
The wierd thing im stumped on is that the tuner does not turn with the channel button like my other combo does. This one only is operating the phono reject.
Originally Posted by DaveWM View Post
Mine just has a regular AC plug from the TV that that plugs into a socket in the stereo chassis IIRC
Old 12-08-2009, 09:41 PM
I had a broken wire on my tuner motor that made the push switch not work. It was right un near the switch. The clicker would move it but now the switch.
yes B&W on mine.
Old 12-10-2009, 02:25 AM
freakaftr8's Avatar
Convergence freak!
Update! She works! Decent picture too but I had to bypass the reciever switch mode that operates the tv part. Not too sure what's going on yet but the remote doesn't work and the channel button won't move the tuner. So so something in the reciever is bad. Hey what does a blue glow on the side of the HOT mean? Is this a over current issue? Flyback is staying relatively cool. Focus is not the best. Probably needs a new focus tube.
I'm not knocking the maggies but the two combos that I have had just seems that the picture quality is just not up to par with zeniths and rcs's of the same era. Kinda washy and dim like. Is this normal for the magnavox's?
Old 12-11-2009, 04:03 PM
freakaftr8's Avatar
Convergence freak!
Actually I think the problem is in the selector switch now that im looking into it. But I might not repair it as I think Im going to build a relay into the system to turn on the TV in the AUX mode and run the sound from the TV into the AUX sor better sound quality. My question is are you supposed to pull the sound from the amp before it gets to the tuner or something?
Old 12-11-2009, 04:11 PM
freakaftr8's Avatar
Convergence freak!
Nevermind, im going to direct drive the AUX off the VCR's stereo output! this will be just dandy! Then im going to put a relay inline for the AUX selection to drive the TV so I can feed audio into the AUX and power the set. ESR on the filters for the reciever and AMP seem good too.
Old 12-11-2009, 07:24 PM
ctc17 ctc17 is offline
These are neat sets. I would grab a color one if it came up. I have seen a few bw ones and had to look the other way. The owners wanted what i thought was way to much for a bw combo.
I have also had terrible luck with large bw crts being dead. All but 1 in my collection are just about unusable.
Would love to see some pix of the inside of the tv and receiver.
I have coffee table looking thing with that tuner in turntable in it and it also has the delayed stereo indicator.
Old 12-11-2009, 08:34 PM
freakaftr8's Avatar
Convergence freak!
Yeah i'll snap off a few pics later tonight and post them.. Im going to do that mod too and see if it works.
Old 12-12-2009, 02:18 AM
freakaftr8's Avatar
Convergence freak!
So far here is what I got. Inside the reciever on the combo selector switch there are these rocker pan switches that operate off the fingers on the main switch, there are two, one for phono and one for the TV. The switch was smoked and a wire burned off. Since I was going to mod the unit for the reciever to operate with the TV for AUX input through a VCR I decided to crosswire the wired from the switch closed. The treble switch still shuts off the whole unit so this mod is ok for me, the only thing that sucks is if you are going to listen to a phono ar the radio, the TV will still be on. But I might just wire a bypass switch on the back of the unit for that. I have not tested tubes yet but the picture is really strong, better and better with use.
I tested the cathode current at a cool 185ma. Thats good enough for me to leave it alone. The flyback stays cool. Here is what I have so far.
Pics dont really do this unit justice and the CRT looks way better than the pics. I have to retract my previous statment, I guess magnavox's can put out a great picture!
Old 12-12-2009, 02:22 AM
freakaftr8's Avatar
Convergence freak!
BTW, that's a HI Lite 23v. And the phono is in great condition too. There are two phantom remotes but for some reason they dontoperate the set. Still gotta look into the remote reciever probably. Also when using the channel selector switch, all I hear is the phono reject, as the tuner channel motor wont operate, im going to test for voltage at the motor.
Old 12-12-2009, 09:01 AM
on mine I had a shorted transistor on the receiver, when I would put it in the remote mode, you could hear the volume relay close and stay closed. All the caps were bad as well (the electrolytics that is).
Pictrue looks great btw!
Old 12-12-2009, 11:14 AM
freakaftr8's Avatar
Convergence freak!
Thanks Dave, thats OTA transmission UHF. Comes out of Monerey, CA about 150 miles from here suprisingly comes in well.. Oh how I miss OTA transmission. Wow. I have ran only into one set with bad electrolytics and that was a 1964 Airline color roundie combo I had a few years ago.
Old 12-12-2009, 11:20 AM
That's a nice lookin' Maggie Shawn, Mine looks the exact same inside, makes me want to dig it out and get it going again. These sets have their issues but hell, they still made it 40+ years and that deserves some credit IMO. When given some TLC, and everything on the board gets resoldered they are great sets.
Old 12-12-2009, 11:27 AM
freakaftr8's Avatar
Convergence freak!
Yep! I know all about the dreaded resolder jobs on these Maggies, this would be technically the fifth one for me and 4 otta 5 needed major resoldering work on the chroma and horiz circuits..
Old 12-12-2009, 03:30 PM
Kalamazoo-DJ's Avatar
Kalamazoo-DJ Kalamazoo-DJ is offline
Wow that is nice, I am sold on Maggies myself, I always liked Zenith/RCA/GE and never even considered maggies now you couldnt pry it out of my cold dead hands!
