Old 12-05-2009, 01:24 AM
freakaftr8's Avatar
Convergence freak!
Another Maggie combo!
Well, I found onother one, this one was in Lincoln, CA at an estate sale. Clean and not sure if it works yet. This set is probably older than the other Magnavox I have. I have two phantom remotes and I took a peek inside the cabinet and theflyback is on the left so the chassis is older. Also it has a replacement CRT, it's an RCA hi lite dated 9th month of 1981. No cataracts, thats a plus.
It does have the big 15" woofers and AstroSonic sound!!!
Cool thing it has a repair tag on it repaired here in Carmicheal, CA. Close to my house.
Old 12-05-2009, 06:29 AM
nice and with those 15" woofers it gonna sound GREAT.
I hope you do the stereo mod to the tv circuit, drive the astro direct from the box, makes fine tuning the sound/video a non issue (just get the best pic since the box is tuning the sound)
Old 12-05-2009, 12:22 PM
freakaftr8's Avatar
Convergence freak!
Yeah thats a great idea! I know these sets are finicky with fine tunung AGC and sound buzz issues.. I thought it was just mine but I hear others have the same issues.
How does the mod go again??
Old 12-07-2009, 10:45 PM
freakaftr8's Avatar
Convergence freak!
Hey guys, I started to look into this set today (no work cause it snowed like 2 feet and nobody in CA can drive in the snow and took out a power line)...
Anyway, so I checked out the guts, cleaned out the innards and the fly looks ok, caps visually good. Stereo looks clean and no visable issues, and the record player turns freely, the chassis is a U90124 1B dated 10/1965. The two phantom remotes at first were a little frozen, I cleaned them out and work nicely now.
So I went ahead for the money shot.. Plugged her in and... Nothing.... Dead, not one single sign of life at all. So prelimary chechs resulted in a bad circuit breaker, So I went ahead and soldered in a 3amp 125v fuse in its place (dont have any circuit breakers on hand). Plugged it in again, viola. Got lights on the stereo. no audio on FM but I got scratching sound while adjusting volume. SO I cleaned the contacts with Deoxit and started to hear audio. After a while fussing the controls I managed to bring the Astro Sonic sound back in all it's glory.. Man does this reciever kick with those 15" woofers!
So I decided to move on to the TV. Pulled the HOT and turned the selector to the TV position..
Nothing.. Dead as well, So once again, I checked the chassis out.. There is a relay in the chassis that the other side of the circuit breaker red wire does to is dead I think.. Thats how far I got so far, has anyone ever had these relays go bad, contacts or something?
Old 12-08-2009, 08:54 AM
those astros can be impressive, and like you said the 15" are the way to roll. does it have horns also? any excess noise from the amp (try aux and turn the volume up, I get a noticable hiss starting abbout 50% volume with no signal.
on mine I had several bad caps, just replaced them all, easy with the pcb solder sucker iron. My hiss was bad at 1st, replaced a few driver transistors.
On more thing does your stereo light come on right away or is there a delay, mine take about 8 seconds to come on, even though the radio is playing and rec in stereo.
Old 12-08-2009, 10:31 AM
freakaftr8's Avatar
Convergence freak!
Actually this is my third Astro Sonic Dave, and I must say the best one yet, yes it has horns, and I can crank the volume to max on Aux and barely noticable hiss from the speakers is present. Looks like the drivers were replaced at some time, this unit looks like it had regular service done to it suprisingly. The panel light comes on right away. I did have that issue with my other Maggie combo bout a year ago and I cleaned the contacts on the remote reciever and somehow it took care of that problem along with scratchy volume issues if using the remote for click-click-click-off three level volume control to unit off.
Hey on yours when you move the selector to the TV function, does your stereo indicaor light stay on or does it turn off when the TV powers up?
Old 12-08-2009, 10:46 AM
sampson159's Avatar
sampson159
i have one of those astrosonics too.the stereo will blast!very good sound from these units.the tv works well and the cabinet is really sharp.in my garage.been trying to find a home for it with no luck.have the remotes and it came from a very elaborate home in bexley.i guess those rich folks back then called up lazarus and ordered the" best one you got "ie:most expensive.although i am not a fan of the tv,the stereo s were some of the best ever.
Old 12-08-2009, 10:51 AM
I will check but think it is off when TV is on. Just to me sure we are talking about the same light, its the stereo indicator that has a delay when 1st turned on. You have to have it set to FM stereo, power off and been off for a few min. Then turn on using the Treble on off. the stereo comes right on but the stereo indicator takes at least 8 seconds. If I turn off and right back on, or if I just switch from another function (like TV, AM, or anything else but FM stereo to FM stereo the indicator works instantly). It like its tied to some cap that needs to charge at power on.
I think I have a decoupling issue somewhere in the radio. the lowest section of the remote does not mute, in fact if you unplug the remote it still has a low level of volume. I did not replace the filter cap, so maybe some signal is not being decoupled there in the amp section.
Old 12-08-2009, 12:16 PM
freakaftr8's Avatar
Convergence freak!
I don't believe any of my maggies ever muwd at the lowest section. It's just a three level volume control all depending on where you have the volume selector set at. The indicator you speak of is the backlight for the am/fm dial right? You most likely have a dirty contact as the backlight is wired to the control selection knob I believe b
Old 12-08-2009, 12:18 PM
freakaftr8's Avatar
Convergence freak!
Oh and does the light delay from phono back to fm/am/aux? Could be a flaky bulb socket.
Old 12-08-2009, 01:01 PM
no its not the backlight its the one that is driven off the MPX board and illuminates the "stereo" uses a transistor as the driver (not switched).
Old 12-08-2009, 02:35 PM
freakaftr8's Avatar
Convergence freak!
Oh that puppy. Yeah mine takes 5 seconds to illuminate.
Old 12-08-2009, 02:39 PM
ok just a normal thing. If I ever get a schematic on it I would like to review to see what is going on.
Old 12-08-2009, 04:28 PM
freakaftr8's Avatar
Convergence freak!
Hey if anyone has a schematic on this unit do you know which wires go back into the tv chassis for power. I'm thinking that the stereo reciever when switched to tv mode is not giving the tv chassis power.
Old 12-08-2009, 04:33 PM
Mine just has a regular AC plug from the TV that that plugs into a socket in the stereo chassis IIRC
