Old 08-12-2009, 11:05 PM
whew done....
restuffed the last can cap (4 section shorty), replaced 4 power resistors (all out of spec, one was 100% out of spec). The only thing I did not do that I wanted was to replace the old diodes, and add a dropping resistor. The diodes are fine, but very old, and the B+ is high by about 20v (maybe just the increase in line voltage, plus my doublers are 147 vs 130, but that is just a guess). I will make up the new diode pair with a 2 ohm dropping resistor built in. The neat thing about it is the diode mount on the top of the chassis with female spade connectors, so I can do it with out pulling the chassis.
I was also thinking about adding a thermistor to the B+ to slow the power up and let the tube come up to heat before the full B+ gets to them. I may put it in line with the switch to soften the blow to the switch, not sure about all that.
I think the contrast has improved with the recap, I may be imagining it but I don't think so.
I hope to get it setup in the living room, will then be able to watch TCM old movies from the 40's and 50's
The Tingler
The Blob
Casablanca
The day the earth stood still
House on haunted hill (orig of course)
The Haunting (orig again)
Psycho
The Foutain head
High noon
Sargent York
Stalag 17
Invasion of the body snatchers
Tarzan (all with the real Tarzan and Jane of course)
just for starters
TV
Outer limits
twilite zone
andy griffith show
you bet your life
perry mason
drag net
wild wild west
the munsters
Gosh so much good stuff, yet very little of it on cable....
I would love to have an outlaw analog tv station
with all the channels we have it is amazing the lack of good programming, and they don't even have to make new stuff just play the GREAT programming from back in the 30s-60's
Old 08-12-2009, 11:53 PM
Sounds good, looking forward to some pics. I'm glad you got 'er finished. That's a nice looking set.
Old 08-13-2009, 08:04 PM
been having some issues with the spot that results when you turn of the set, not sure why this one does it an my other does not, but a quick fix was to put a resistor/cap in series from the crt cathode to ground. The cap charges during normal viewing, when you turn the set off, the cap discharges into the cathode holding it positive while it cools off biasing the tube for about 15 seconds, no spot. I was worried that it could burn the CRT.
Old 08-14-2009, 12:21 PM
I tried sever RC combinations, 470k and 22uf seems the best for spot control with miminmal impact on time it takes for the full brightness to be achieved when the set is turned on. Again this is just a series connection from the cathode to the ground. during operation the cathode has a positive charge, when the set is turned off this charge goes away, and the spot comes on (very bright dead center of the screen). by using the RC combo the cathode maintains a positive charge long enough for it to cool down and stop emitting.
Old 09-19-2009, 11:38 PM
update on this set, I think I lost a lot of post but it is the one that was having the hula problem, or snaking or maybe even weaving.
bottom line is there was a low freq low amplitude wave that would work thru the screen. You could see it on vertical lines. the wave would repeat about every 15 seconds and would deflect the vertical lines (like a foot ball field) about 3/16 of an inch.
I was able to get rid of it if I powered the vert sync tubes heaters with DC.
no HK shorts (swapped tubes from a working set).
tried cleaning PCB traces along the filament trace, no help
had all new E caps (filter/decouple/doubler)
finally got it licked by adding a direct ground connection from the two vert tubes to the chassis ground.
Those two tubes use the PC traces for a heater ground return, and the PC trace is grounded via some solder fingers that press against the chassis.
I may have been able to just tighten up the screws, but I figured the direct wire to chassis was more of a sure thing. Seems kind of lame to rely on just a press contact point for a ground. The horz osc tube had its own factory ground wire, and did not rely on the pcb for a ground path on the heater.
any way it did tighten up all the pcb screws on all the boards jic.
anyway learned something new, small problems (the wave was very minor but there) often have small causes (I prob could have fixed it by just tighting up the screws).
Small causes can still be hard to find, maybe harder since they are not obvious. But anyway you can bet for now on all pcb screws will be checked 1st thing.
Old 09-20-2009, 10:25 AM
Charlie's Avatar
Charlie Charlie is offline
On Land
Glad you found your problem! I've heard many guys here emphasize checking ground connections... especially between circuit board and chassis.
Charlie Trahan
Old 09-20-2009, 11:58 AM
roger that Charlie, you can bet that is the 1st thing I will check on any set I get that has PCB's for now on
I am just glad it is working, It was really starting to bug me.
the screws were not loose, but I was able to tighten them all up about 1/4 turn. I guess with age it was just enough oxidation to cause a problem.
I have another maggie with the same chassis and you can bet I am going to check them.
Old 11-15-2009, 11:38 PM
Update"
Got the new CRT tester (Sencore CR-70) tube show nothing on emissons and cutoff, according the the "beam rebuilder" guide I did rejuvenate, nice little sparks fly in the CRT neck and I am think Oh fudge now what have I done. Anyway checked and solid in the good and great cut off.
I turn it on and the focus is much better and the picture looks pretty darn good. I hope this fix last.
I like the Sencore.
