Old 04-09-2009, 03:58 PM
RCA in Milwaukee for 20 bucks
http://milwaukee.craigslist.org/for/1110723631.html
Not mine ect.......
Old 04-10-2009, 07:34 AM
batterymaker's Avatar
Repro Battery Builder
EARLY one--is it about 1949 vintage?
Old 04-10-2009, 11:46 AM
ohohyodafarted's Avatar
Bob Galanter
I put in a call to him. Waiting to hear back.
ME http://AntiqueTvGuy.com
Old 04-10-2009, 01:10 PM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
tvhistory.tv says 1948.
Bob, I hope you get it. I'm sure you'll do that cabinet justice.
John
Old 04-10-2009, 02:23 PM
Oooooooh...Dat's an OLD one...Hope one of "The Clan" here gets it...Hate to see sumpin like that go to a "Civilian" who promptly turns it into a feckin' wine rack or sumpin' equally as inane...
Old 04-10-2009, 07:32 PM
I have an Uncle in Milwaukee I could store one at till I could get down there. Unfortunately he does not drive:-(
Old 04-10-2009, 09:37 PM
Bob Galanter
The seller called back tonight. I will be picking it up on Monday.
Thanks Mark for posting this one. Cant go wrong for 20 bucks.
Bob
Old 04-10-2009, 09:44 PM
kvflyer kvflyer is offline
Thanks for not letting this item go to the dump! It can be an easy restore...
Old 04-10-2009, 10:02 PM
Bob
You're welcome Bob, I was hoping you would grab it. I have way too much going on right now, it should turn out to be a beauty.
Old 04-11-2009, 10:38 AM
Awrite !! ANOTHER old veteran saved...Way to go, guys !!
Old 04-15-2009, 07:56 PM
Bob Galanter
I picked i up yesterday. Took two strong men and an appliance dolly to hoist it out of the basement. It weighs a ton!
Finish is quite nice except for a couple of dings in the corners which have been mashed in. Best fix will be to stain and varnish the dings and be done with it.
Crt is only fair. It is the original. With a Beltron cleaning I got 9 seconds life and about 85 micro amps.
CRT measures 420 on a scale of 1000 on the B&K 465.
This is a chanel 1 set.
It will be years before I get to restoring this one, but now it is safe from the dumpster at least.
Bob
Old 04-16-2009, 12:00 AM
This is a channel 1 set.
Bob
If you do get it up and running, you might be able to feed it a channel 1 signal if you modify an old VCR's TV modulator like I did in this article: http://www.audiokarma.org/forums/sho...d.php?t=220321 As the picture carrier is on 45.25MHz, one third of that is about 15.0833MHz, and if you can find a crystal of that frequency, and a modulator with the right kind of modulator chip...
