Old 03-11-2009, 10:04 PM
mustang84 mustang84 is offline
my 1st roundie
just aquired my first roundie! rca ctc 16 with a white cabinet.very clean set.crt checks okay-neither god nor bad.i got a picture on it by changing a resistor in the vertical. it was broken in two.now my issue is no color.6gh8a and 6cy6 not lighting up.as i am very limited in my skills (i am willing to learn!),can anyone give me some guidance,always dreamed of a roundie to call my own.
Old 03-12-2009, 06:47 AM
radotvguy radotvguy is offline
mike g
Maybe try wiggling the tubes in their sockets . Might be a bad connection . MAybe even try spraying the socket with electronic cleaner .
Old 03-12-2009, 09:20 AM
that was the first thing i tried.clean out the sockets and wiggled them like crazy! i think it is something electrical.maybe a resistor?i even tried swapping out the tubes with known good ones and the same thing happens.did resolder the sockets.thought i found a loose ground but no change.this is such a nice clean set and i want to put on display in my rec room.
Old 03-12-2009, 09:26 AM
mike g
I aint no expert but i would guess you are not getting your 6 volt filiment voltage there . Guess your going to have to trace it . Might need a schematic though to do that .
Old 03-12-2009, 11:43 AM
bgadow bgadow is online now
Welcome to the club! Let's see...you've confirmed the tubes are good, right? (stupid question, had to ask) Yep, this ones going to take some tracing. I'm guessing a bad trace somewhere-you'll have to figure out where they feed from. If that is the problem fixing it shouldn't be so bad. You could just run a jumper wire to another tube.
Old 03-12-2009, 12:42 PM
Old 03-12-2009, 09:40 PM
marty59's Avatar
marty59 marty59 is offline
Do you have a tube manual at least? Verify the filament pins and check for A/C. Or with the chassis out and knowing the pins then you can do some tracing.
Also a common problem on RCAs' of this vintage is the point to point wire connections on the top side of that Chroma board. The wire will corrode and open up.
Keep us informed!
Old 03-13-2009, 12:19 AM
sampson159's Avatar
sampson159
interesting about your ctc 16.i had the same set in my garage.somehow it came up missing.it also had ground problems.marginal crt and no color.very strange.
Old 03-13-2009, 11:44 AM
Ron, was that the white one, that came off the ETF classifieds? Interesting...
Old 03-13-2009, 03:05 PM
Old 03-13-2009, 03:30 PM
sampson159's Avatar
sampson159
that is the one.funny how now it appears in lancaster and my friend won t return my phone calls.going to make a visit and find out how this happened.
Old 03-13-2009, 10:59 PM
Tony V's Avatar
Tony V Tony V is offline
Interesting.....
Old 03-16-2009, 02:02 AM
sampson159's Avatar
sampson159
i got it back.was stolen and sold at an antique shop on rt 33.randy paid 50.00
for it.he had receipt.i will take it up with them later today.after looking at some "repairs",maybe i didn t need it! i will give him enough parts to build a roundie to keep.i have a cabinet,a working chassis and a 21cyp22 crt.it checks good,however,i have never jigged it up to see actual raster.they also took my old philco tabletop.rca has too much solder work-3-4 rolls of braid to clean up.i spotted problem already.corroded wiring by those pesky 6cy6s.easy to spot with glasses!glad to get it back,but almost lost a good friend. it was a roundie after all.you know how we get when you mess with our roundies!
Old 03-16-2009, 12:53 PM
Glad you got it back Ron!
Old 03-16-2009, 01:14 PM
Tony V's Avatar
That is so bizarre. What are the odds of having it stolen, then sold, then the new owner posting for help on it on here? Keep us informed on how this ends and of course how the roundie comes along.
-Tony
