Old 11-01-2004, 09:33 PM
phonograph
inside shot. That silver rectangular box on the far left side is the reverb springs. Next to that is the FM multiplex chassis. (the pic flash makes the 3DG4 look like it went to air)
Old 11-01-2004, 09:35 PM
back. Larges ventalation holes ive ever seen.
Old 11-02-2004, 01:48 PM
asynchronousman's Avatar
asynchronousman asynchronousman is offline
Banned
Deginitely not...
Originally Posted by heathkit tv
Inline CRT? That sorta reinforces my first thought that this set kinda resembled a Portacolor. The SSK nameplate may be a subliminal attempt to gain some prestige as there was a very fancy schmancy Mercedes Benz model with that same name back in the 30's.
Anthony
That is a gen-u-whine KMart logo and was so when they came to our area in the middle 70's. S.S Kresge Corp until the higher ups decided to change it to KMart. The old man's picture is buried in the back of the store next to the restrooms, if that says something to ya, whereas Wal-Mart is so owner-centric that they even named the dog food after his ol' hunting dog, Ol' Roy.
Old 11-02-2004, 01:53 PM
Banned
Doug, that is so sweet! I can't think of too many words right now. Stunned.
Old 11-02-2004, 02:06 PM
Charlie's Avatar
Charlie Charlie is offline
On Land
Motorola
Doug,
That Motorola is quite impressive looking! They weren't beatin around the bush when they built that thing! Big 16" center channel and six 6V6's... that baby is ready to rock!
Does it have a set of AUX/TAPE inputs so you can connect a CD player? I've got a CD player plugged into my B/W Curtis Mathes entertainment center, and the sound is extremely impressive coming out those 12" speakers using only two 6BQ5's. I would think that your Motor's sound probably kicks some serious ass!
Charlie Trahan
Old 11-02-2004, 07:12 PM
It does have a tape/aux input! RCA Jacks. It would be nice if more consoles had that. My other consoles, I would need to transmit a tape deck on FM so I could hear it!
This thing really blasts loud. The manuals says this unit is 51 wpc. Im not big into cranking up the sound. I think all the talk about power output and watts is a bunch of bs. Too many people get in arguments over "my system has more power" crap. Especially these kids today with these little pos modified foriegn cars w/ overkill sound systems that you can hear from 2 miles away. Like a 500hp engine in your car, you dont need it but it makes you feel good to know its there, and you can brag about it to impress everyone. My saba 2000 console is only 10 wpc and that is one impressive sounding unit. Ive put a signal test to it, and it can produce a clean 25hz upto the end of my hearing range which is about 17khz. As long as the unit has a broad frequency coverage, it sounds great to me.
Old 11-02-2004, 08:30 PM
Where's the control panel?; long-neck CRTs; CRT shorts
Doug, it's all well and good that you've shown us pics of the record changer, chassis and back panel of the Motorola console; however, how about a picture of the control panel of this beast? Is this simply a radio/phono system or was/is there a TV in there? If so, I didn't see a CRT anywhere. The CRTs in 1950s-'60s-vintage TVs, with their massive, thick and in many cases long necks, were difficult or impossible to ignore.
Speaking of long-necked CRTs, I hate to think how long the necks must have been on early large-screen tubes, such as I've seen on 1950s-vintage DuMonts and other sets. Correct me if I'm wrong or mistaken, but I read somewhere (I think it may have been here in one of the AK television forums) that the larger the TV screen is, the longer the neck of the CRT will be.
Ooops. I just remembered that oscilloscope CRTs, most of which had screens no larger than five inches, also had long necks which extended almost to the back of the instrument's cabinet (this would explain why oscilloscope cabinets are very deep as a rule--at least the scopes I've seen have been like that). I think this would effectively prove my previous statement false (the larger a CRT screen is, the longer will be the neck).
One very large-screen direct-view set that comes to mind as I write this is a 30" DuMont from either the late forties or early fifties, which I once saw here on AK in the b&w TV forum. Man, that tube must have had a neck at least a foot long! The cabinet must have (would have had to be) deep as all get out to accomodate that long CRT neck, if in fact the neck were anywhere near a foot in length. Many sets with 23" tubes also had very deep cabinets, but then again the depth was mostly taken up (I think) by the CRT neck. Can't recall offhand how long a 23" CRT neck is, but I would guess it's a good seven or eight inches.
The 1970s (again I think) saw the introduction of the new thin-neck large-screen CRTs, in which the necks were much shorter than older tubes. One drawback of the newer tubes was that CRT brighteners could not be used with them, as the new tubes had flimsy plastic button bases about the size of....well, a large button. Were there any brighteners made specifically for use with these new button-base CRTs? For that matter, is it possible or practical to use a brightener on a modern CRT? If so, this could save a lot of modern RCA, Zenith, et al. sets from the landfill when their CRTs go bad within a couple years (as is all too common with Zenith-branded GoldStar [and current-production LG-branded] TVs).
If one used an isolation brightener, I would think this could isolate the heater from the cathode and restore the tube, as was common with monochrome CRTs. If this is possible, why don't more TV shops use them, rather than condemning the entire set once the CRT shorts? What exactly happens to the circuitry of these sets, when the CRT develops a HK short, that causes so much damage? I've read here that the video amplifier stages are destroyed when the tube shorts, also the power supply is damaged or destroyed, not to mention other parts of the set. Whatever, the damage must be fairly extensive, as most GS-built "Zeniths" with shorted CRTs wind up in the trash, more often than not.
Old 11-02-2004, 10:28 PM
Lightbulb
Many such sets used a few turns of wire around the flyback transformer core to get energy to run the heater. I've added an extra turn to such to create higher voltage to brighten a weak CRT.
Though I haven't had to try it, an "isolation" transformer that would run at horizontal deflection frequencies should be a toroid (of the sort found in SMPS (switching power supplies) with something like 4 times more turns than that used on the flyback for the heater, for the primary, and about the same or
more for the secondary. Add more turns if the horizontal circuits get unhappy.
Locate it near the CRT but away from the video signal lines.
Old 11-03-2004, 08:53 AM
Chad Hauris's Avatar
The filament winding for CRT works very well on the flyback. Just wrap several turns of insulated wire around the core...2 or 3 seems to usually be right. You may not get an accurate AC voltage reading on a meter as it is high frequency AC...but you can usually judge and see if the color of the lit filament appears good.
I have made a CRT rejuvination setup with a boosted-voltage winding (about 8-volts) on the flyback and a DPDT switch to switch between the original fil winding and the booster winding. You can sometimes get a good amount of rejuvination by leaving the switch on the boost position and then returning it to normal after a few minutes.
You can even do the flyback heater winding for increased heater voltages on the old solid state sets like the CTC-68. Hasn't hurt it a bit, although there is slighly decreased width when the auxiliary heater winding is on. Would not recommend using it on tube type sets as their flyback system doesn't seem to have much reserve power capacity and the auxiliary winding may cause an overload.
Chad Hauris
Old 11-03-2004, 11:13 AM
I used the trick of adding a few turns of wire around the flyback core just last week on a 27 Sony with a blue H-K short. It's best to use a tru RMS volt meter and fine tune the voltage with a series resistor. If you don't have one, you can measure the heater voltage with a regular meter before you modify anything and adjust the resistor on the new winding so it reads the same as the orignal winding. By the time a H-K short has developed, it might not hurt to boost the heaters a little anyway.
I've always wondered why all modern TVs all run the CRT heaters at ground potential. It wasn't uncommon for older TVs to bias the heaters close to the cathode voltage so there's less stress on the heater to cathode insulation.
Old 11-27-2004, 09:05 PM
1956 Admiral find
Got this set in Downers Grove for $5.00. TV was in the living room. The set still works with a bright picture, original CRT! In pretty nice shape too.
Old 11-27-2004, 09:11 PM
Another find in the same weekend! This is from Hillside, IL. Marked $50.00. Got it at half price for $25 as the sale was almost over. This is a 58 motorola, drexel cabinet. This set and the moto stereo console I found a few weeks ago are a perfect matched set! This set was still in the living room too! Plugged in and working great still after all these years! Opened it up, and all original, crt and tubes. Hard to believe these sets survive all these years with slight use, considering they were in the living room of the homes!
Old 11-27-2004, 09:12 PM
This set is as good as the day it left the show room. Not a mark anywhere.
Old 11-27-2004, 09:19 PM
Charlie's Avatar
On Land
Man, Doug! Both of those sets are beauties! The cabinets are awesome! It's amazing that someone was able to keep the kids fingers off them for all those years!
Charlie Trahan
