Old 12-30-2007, 08:55 PM
oldtvman's Avatar
oldtvman oldtvman is offline
Larry Melton (oldtvman)
early Network color was not equal
In the thread regarding the Patriots-Giants game there was mention by Pete and others as to the color quality on certain channels.
The same could be said for the early network color broadcasts, while Nbc was consistently the best, Cbs using the norelco cameras always looked different, and Abc also couldn't compare to the NBC guys.
[IMG]
Old 12-31-2007, 12:05 AM
Pete Deksnis's Avatar
15GP22 demo @ ETF 2007
For the record, here's an NBC screen cap taken tonight along with one from CBS. Both are slightly overexposed, but you get the pasty picture look from NBC. For comparison there's a color bars cap from few nights ago. All are from the same CT-100. I'm wondering if NBC analog didn't lower saturation and add some custom aperture correction to get this crappy flat look?
Old 12-31-2007, 07:01 AM
yagosaga's Avatar
yagosaga yagosaga is offline
VK Member
Why is the yellow of the color bars dim in comparison to cyan and magenta?
Yellow should be the brightest color of all colors.
- Eckhard
Old 12-31-2007, 09:08 AM
Originally Posted by yagosaga View Post
Why is the yellow of the color bars dim in comparison to cyan and magenta?- Eckhard
Good question Eckhard. Besides the usual distortions introduced between the CT-100 screen and yours, mine, and everyone else's, the green is weak. By way of explanation, let me share with you this recent email I wrote:
"Those of us directly involved with the 15GP22 project last May at ETF 2007 were relatively pleased with the results, as has been stated before. Not all was perfect of course and so I have attempted to address the most serious anomaly, the poor color bars green-to-magenta transition.
To that end, I acquired a B&K-415 generator with the specific purpose of sweeping the chroma circuitry. Before the first attempt however I used a Fluke 77 to troubleshoot a pesky rare intermittent that has been plaguing me on and off for over a year — bright flashes of green in the picture.
Turns out the Q demodulator plate load resistor was running 50 to 100 percent high depending on how it was bumped. But unexpectedly there were a number of off-value resistors in the R, and G, amps.
As you can see in the accompanying photos, there was distortion in about the first 25-percent of the magenta bar (overexposed screen image shows it off well) before the fix, but a close up now shows much improvement afterword.
With three replacement resistors in the amps and the new 18K plate load the set was stable although no longer calibrated. The picture looked ‘orangey’ with brownish greens.
Last night I ran a complete new calibration beginning with red purity. The results were quite nice. I suspect better than ever.
A word about calibration: before the fix, both the B and G Drive controls needed to be fully CCW; now the picture calibrates with them cranked up somewhere in mid range.
The full range of color on the Robin Hood DVD is back, having been lost after the fix. Purple is royal again; trees are green again; Maid M. has stage-makeup red lips again.
I also touched up the convergence and lucked out as I managed to avoid a slippery slope and the need to start from scratch; photo attached.
The color bar screen photo was taken to illustrate the much improved G-to-M transition, the most technically challenging in NTSC bars, and it was taken before the set was recalibrated.
Henceforth Eckhard, you shall be known as eagle eye.
Pete
Old 12-31-2007, 10:04 AM
OvenMaster's Avatar
DTV blows
Even today, I've noticed the colors vary from station to station.
I've got access to two of each of ABC, CBS, NBC, and PBS broadcast stations. The local NBC looks bluish and out of focus, the more distant one looks clean, warm, and sharp. (Any coincidence that it's an O&O? I use this one as my picture-adjustment standard.) The local CBS LPTV looks pale and bluish, and the contrast is too high; the more distant one is reddish, but the contrast is much better. The two ABCs look the same, color-wise, even though the distant one's transmitter is about 60mi. away, and the two PBSs are the same: gorgeous.
Heh. I always wondered if the station engineers had to keep the pictures up to a certain standard. Maybe not, eh?
Tom
Tom
Old 12-31-2007, 11:27 AM
oldtvman's Avatar
now and then
I guess today we expect to see uniform color images across the board.
Back in the early days they didn't have all the computer referenced settings and add to that the fact that image orthicons would change charicteristics with temperature changes, and then there was the huge difference in picture quality between rca and any other broadcast equipment manufacturers of the time.
[IMG]
Old 12-31-2007, 07:50 PM
- Eckhard
Take another look - note that there are two exposure levels on the blue due to the shutter of the camera and the short persistence of the blue phosphor. The darker area across the bottom of the color bars is closer to correct. Note also the excess blue at the very bottom of the gray steps.
However, green is still fairly dark. - This could be a combination of low Q gain (or high I gain); the response of the still camera; the matrix in the still camera that converts its raw sensor output to sRGB (which has a smaller gamut than NTSC); or some other factor, like clipping in one of the matrix stages.
Note that the cyan is quite bright (brighter thatn the yellow) even though the green is dark. This leads me to suspect that most of what we see is due to the still camera.
Pete - Some things you could try: you could set your camera for a slower shutter (like 1/8 or slower). Also, you can check if the green appears this dark and the cyan this light to the eye. Also, you could check the relative gain of I and Q.
If you look at the R, G, and B outputs with a scope, you can check for waveforms that are nice and flat and equal-height sqiare waves.
Old 01-01-2008, 01:38 AM
Clearly I have not mastered the new camera, a Canon A630, that takes unbelievably good pictures in AUTO -- if you're taking pictures of people or things other than CRT images. So far I've played with exposure time. Longer exposures (under 1/8 second) seemed to darken the image for some reason and so 1/15 second seems best.
Attached are G1 waveforms (taken waiting for the Times Square ball to drop), plus my best shot of the screen image those waveforms generated. I think you can see an improvement over the other (pre-cal) color bar image. The screen looked okay to me through R, G, and B filters. The A630 overexposes my scope shots, but you can see the red trace amplitude is greater than green and blue, as it should be driving a 15GP22. Vertical sensitivity is 50 V/cm.
I have yet to check the I gain (later today maybe), but the control is so narrow I will be surprised to find a problem there.
1-1-2008
Yesterday after downloading images to the computer and while still connected to the computer I found a menu showing sRGB. There were options for many other color spaces including 1953NTSC, which I promptly invoked. I can't believe it was that easy to shift an A630 to the coveted original NTSC specification. Anyone familiar with the Canon A630 who can make some sense of it? The three shots below were taken after the 'change' if that's actually what I did...
Old 01-01-2008, 08:05 AM
yagosaga's Avatar
VK Member
The unweighted color reproduction is not only due to the camera. I have made two screenshots, both with the same color control position but with changed brightness. You can see that the yellow bar is darker in comparison to cyan with lower brightness, but it is brighter than cyan with high brightness.
These old color tv sets do not provide a full contrast range which is necessary for correct displaying the colors. So, people usually watch tv with low contrast and brightness, but high color control setting. Since the color green is computed in the dematrix circuit out of I and Q and Y, the green (and also the yellow) will be much darker in comparison to other colors with reduced brightness, which is a reduced Y. You have to adjust a correct contrast-rich black and white picture before you add color.
Is this correct?
Kind regards,
Eckhard
Old 01-01-2008, 08:42 AM
yagosaga's Avatar
VK Member
Here is another try of correct color vs. Y relation with the 21AXP22A of the CTC5. Note that the green does not look enough greenish like it is displayed on the screen. This is a true camera artifact.
- Eckhard
Old 01-01-2008, 09:28 AM
Hi Eckhard,
I agree the contrast range must be ideal before color is added; so I went back to my library of shots, ones taken 12-28-2007, and selected this example of contrast range. This remember was taken before the set was calibrated and so the colors are imperfect. However, note the range of brightness from white (that little wedge showing but mostly masked by the roundy CRT) down 8 steps to black. This test signal remember is from the DVE test disk -- it was made for modern digital sets, and the CT-100 displays it perfectly. It seems also that the A630-camera-to-monitor link displays an analog of that CT-100 screen fairly well. So, based upon this and other examples, I suspect the contrast range of this CT-100 is correct.
Keep in mind that the CT-100 was designed to display the 1953 NTSC standard. It may be the only consumer set that could (at least up until today's wide color LCD LED sets, and with those I wonder if they can actually display a full analog NTSC signal or just do the wide color space through a digital interface like HDMI).
I believe the CT-100 will reproduce the full contrast range, decode the full chroma signal in a wide-as-possible bandwidth (ameliorated by issues with the quadrature encoding-decoding scheme), process that decoded chroma in a 1953-correct NTSC matrix, and display the resulting RGB signal with 1953 NTSC spec phosphors. I don't know if anything other than a true clone of the CT-100 can do those things.
A word about calibrating the CT-100. My method or methods for adjusting a CT-100 come from multiple sources (oh to be able to watch the CT-100 techs setting up these sets coming off the line). The well known SAMS and other sources are basically derivatives of RCA material. But fortunately, one of the Zenith engineers deeply involved with color set design back in 1953 casually related a bit of kernel information that promotes linear operation of the video circuitry (an advance rather than retard thing when setting the screen controls early in the setup procedure). A luckly bit of history available today.
Pete
Old 01-01-2008, 09:46 AM
Nice 21AXP22 shot. Looks eyeball-great on my monitor AND particularly good through R, G and B filters.
Old 01-01-2008, 11:28 AM
yagosaga's Avatar
VK Member
Hi Pete,
take this file
http://bs.cyty.com/menschen/e-etzold...mg/rainbow.JPG
burn it on a CD, and play it with a DVD-player. What would it look on your CT-100?
The white is 100%. Contrast and brightness at maximum with a bright white and a dark black, just before blooming, and then add color.
- Eckhard
Old 01-01-2008, 01:43 PM
Hi Eckhard,
Not sure what the exercise will demonstrate. But there are two things it would look like that depend on the hardware involved; indulge me and check me to see that we're on the same page:
[1] Take a 'perfect' or reference color bar (as you have provided) and reproduce it on an sRGB TV or monitor driven via component or DVI or HDMI, and you get a 'perfect' (okay, really, really good) color bar image. I've done that and photographed the sRGB-phosphors screen with an sRGB digital camera and generated an sRGB color space jpg. It can be seen here. link.
[2] That same reference color bar signal turned into an NTSC signal by a DVD player [and either modulated or directly introduced into the first video amplifier (which is the way I do it)] is going to be corrupted or at least constrained by the NTSC system and the DVD-player version of NTSC. I think I would see what I see now since the color bar pattern on my DVD is essentially reference quality before it takes the long NTSC route to my 15GP22 screen, and as I have noted above, the brightness/contrast range is already adjusted correctly as shown on a screen shot earlier.
There is another factor not yet mentioned -- that of high-voltage. Your CTC5 has what, 25 kV to play with and the regulator is far better than the 6BD4 circuit used in the CT-100. (Even, by comparison, the Westinghouse H850CK15 has, by observation, a far more stable high-voltage supply.) Not an excuse, but blooming by the Bloomington set is a salient factor in the available brightness/contrast range issue.
Pete
Old 01-01-2008, 02:11 PM
yagosaga's Avatar
VK Member
Hi Pete,
This file has 100% saturated colors and 100% white. The reference color bars usually have 75% saturated colors due to the fact that the amplidute of the red signal might be overloaded with 100% saturated color. So, with this file you can test whether the RGB drive is proper operating. (If the tubes are tested good on your CT-100, it should operate properly.)
For comparison: I have displayed the color bars on my computer monitor, and photographed it. See the file in the attachment. You can see that there is a bias toward blue in the green, but the other colors seems to be OK (within a large range of standard error). Now you can compare the monitor screenshot with the screenshot of the 21AXP22A.
I feed the video signal as R.F. signal directly into the tuner of the CTC5. So I get a nearly perfect impression about the disadjustments and the losses in the color channel up to the screen of the 21AXP22A. (Note that I have to convert the PAL signal into NTSC which means an additional loss of signal quality, especially in the transit between magenta and green.)
High voltage in the CTC5 is 19.5 kV according to the manual, and I have controlled it.
I believe that your CT-100 has a much better color performance than it is shown here in your demonstrations, and this is what I want to prove with these tests. When I got the CTC5, I misadjusted color and brightness a lot of times before I understood how it works. I did only know the PAL tv sets, and they are working different.
- Eckhard
