Old 10-24-2007, 12:23 AM
joeseattle70's Avatar
joeseattle70 joeseattle70 is offline
Question Need Tuner Dial Light Bulb
Does anyone know where I can get a tuner dial light bulb - it is for my ctc-44A chassis RCA trans vista color tv from 1970. I can't find anyone anywhere - I substituted the UHF bulb for the VHF for now (just blew out), but would like all operational. Any leads would be appreciated. No schematic is to be found anywhere, and i don't have the model number either - the tag is long gone unfortunately. Again, thanks to all of you who helped me get it up and going again! Joe
Old 10-24-2007, 01:02 AM
Is there a number on the base of the bulb? If so, you might could get one from Radio Shack or Antique Electronic Supply (www.tubesandmore.com).
Old 10-24-2007, 10:09 AM
It's probably 6.3v, but you should check. As radiotvnut said, there should be a number on it. These are standard lamp types that are still available today.
Old 10-25-2007, 04:06 PM
Findm-Keepm's Avatar
Followin' the Rules...
It's not one of the bi-pin lamps, it it? RCA used some of these - if it is a bi-pin lamp, I've got some. There are two types - both have a black metal cylinder around the bulb - one type has the cylinder open at the end, the other with a closed end and a rectangular window in the side.
Cheers,
Brian
USN RET 22YRS (Avionics/Cal)
Old 10-25-2007, 07:09 PM
dgwojo's Avatar
dgwojo dgwojo is offline
Away 8/14 -->8/16/2009
Get the number off the original lamp and we'll see if we can help you, I have many bayonet base lamps if that's what it takes, Dave.
11-Altec A7(515/802/511B/N501),Model 19(416/802/811B/N1201),Model 18(604-8H),604-8G,8K,604C,604E,Model 9,EV Interface D,LT12,Koss CM1030.
Soundcraftsmen MA5002,MA5002A,Pro-Power3.
Toshiba SD5700(8),SD4700(4),SD3750(9).
RCA 10 band EQ w/expander(3).
HK Citation 25(2),Mac C27,1700.
Marantz 2270(3),4300,2285B,2325,2226,2230,2240,2245,2250.
Lafayette LR1500TA(2),Allied 395(3),Pioneer SX1010,850.
Old 10-25-2007, 09:15 PM
Guessing it's a #47 lamp?
Old 10-25-2007, 10:41 PM
dgwojo's Avatar
If it calls for a 47 then use a 755, 7x the lifespan. Dave.
Old 10-26-2007, 11:35 AM
kx250rider's Avatar
REAL TVs have TUBES!
The 47 is still a common lamp. I think even (the formerly beloved, now hated) Radio Shack has them, maybe in the catalogue if not in the stores.
Charles
Old 10-26-2007, 01:12 PM
So 40 years x 7= 280 years!, that should be sufficent.
Old 10-26-2007, 05:47 PM
Your set uses a #219 bulb. RCA p/n 117435. Its a 6.3v 250 mA bayonet base with a spherical envelope. Very important to use the correct bulb, especially in an RCA. The #47 will be too close to the dial drum and will create a burn mark on the channel strip.
You should replace the other bulb too. Im surprised it worked when you swapped it out. Every time I pull a tuner with its original working dial lamps and then reinstall, 9 times out of 10 the VHF bulb won't light!
Here's a place online who has them in stock:
http://www.electra-ica.com/special/microlamp/
