Old 01-23-2007, 10:51 PM
peverett peverett is offline
Philco Seventeeners
I have about 5 of these and have began restoring them. The first one went fairly smoothly with all of the integrated RC networks being good. I replaced all paper and electrolytic caps, a few resistors, a couple of tubes, and cleaned the controls and all was well.
As I do not expect this to always be the case, does anyone have hints that they would like to share about these.
Old 01-24-2007, 12:03 PM
Ex-Philco
Are they Seventeener I, II or III? They are very different.
Seventeener I is the original E and F series with the teardrop style cabinet.
II is the box style with F series model numbers and 8H## chassis numbers
III is the briefcase style that was the most popular.
Don
Old 01-24-2007, 10:10 PM
The five that I am presently working on are briefcase style, made in 1958 and 1959. There are some minor differences between the two years such as using a solid state diode array in the horizontal section in 1959 and a twin diode tube (2EN5) in 1958.
I also have a somewhat thicker Philco that is similar to the Seventeener that I also want to restore. It was also made in the late 1950s.
Old 01-25-2007, 01:46 PM
Ex-Philco
The briefcase Seventeeners are fairly reliable. It has improved sound and a cooler chassis layout than earlier models. Troubleshooting is straightforward. Check out electrolytics and a couple of black caps in the vertical. Align the horizontal oscillator. Check tubes as usual.
The "box style" Seventeener 2 is a little more troublesome. It runs hotter and needs to have yoke wiring rerouted around the 15 watt filament resistor and damper to avoid fire. Virtually every original yoke (made by RCA-274 code) went bad. If it works at all, it must have been replaced. A 12K 2w resistor in the B+ power divider, caps in vertical, PC grounds, input electrolytic filter, AGC divider resistors, sound IF can and horizontal diode are all trouble spots. It will have some intercarrier buzz so don't spend a lot of time trying to get it perfect. The chassis was reworked for the first-year low end Predicta. That one can keep you busy.
Old 01-25-2007, 10:21 PM
What years were the box style made? I have a thicker Philco TV, but the styling indicates it was made in the late 1950s. It is similar to the Briefcase ones that I have. I have seen the earlier Philco portables that are thicker. I do not have these-are they the box style?
Any hints about replacing the RC networks used in the sync, vertical and horizontal sections of these sets? Sams shows the internals, so I had planned to use individual components if replacement is necessary. I did this on an Admiral metal Square Box TV made in 1955 and it worked ok.
I have noticed that the contrast control on the Philco Briefcase TVs is unusual. It controls the AGC instead of the video amplifier gain.
Old 01-25-2007, 10:29 PM
I took another look at the thicker Philco I have. It has different knobs than the briefcase models, but has the same built in antenna in the handle. The metal case is in two pieces with a plastic back. The horizontal hold, vertical hold, and brightness controls are in the same place as on the briefcase models, the top of the back.
I would try to get the model number, but it is kind of hard to get to at present.
I am presently working on my second briefcase model. So far, the bigest pain has been unsoldiering and unwiring(where necessary) the pc boards to change the capacitors, etc.
Old 01-25-2007, 10:35 PM
I just noticed you comment about intercarrier buzz. I got it pretty well out of the sound on the first one that restored. Not completely, just pretty good.
It seems that is one problem with all of these early sets-all brands), either with a ratio detector or the pentode detector. You could probably do better if you completly re-aligned the set, but I do not have time for that at present.
I have a couple early 1950s RCAs with the limiter, discriminator setup which I hope to get to soon. I want to see how this works. (That these sets used this circuit is supprising considiering the fighting at that time between Sarnoff and Armstrong).
Old 01-26-2007, 12:42 PM
Don, those tips may be helpful for me. I have a Seventeener II which I took apart some years ago. I had it running but then something was killing the HV. I didn't have the Sams at the time so I stuck all the parts (I didn't want to go to the trouble of putting it all back together) in a big box. Has been up in the attic waiting for me for quite a while. With these tips, maybe I'll start with checking the yoke. That Philco is far from the easiest set to work on.
Old 01-26-2007, 12:52 PM
Ex-Philco
Also check for leaky/shorted caps from boost to B+.
Don
Old 01-26-2007, 07:24 PM
Don
Don, weren't the teardrop sets called Transitone or something like that?
I always wanted one but never found one in the right place at the right time or price.
Old 01-26-2007, 08:03 PM
Ex-Philco
Eric:
Yes, the 1957 "E" line portables were called Transitone. They were available in a 14 inch and 17 inch version. The chassis were quite different. I have both versions. They were continued over for first half '58 "F" line, with some improvements. The rotating handle-antenna is the most noticeable. Philco did not offer a 14" after 58.
Transitone was originally a car radio manufacturer in Philadelphia that was bought out by Philco. Philco continued to use the Transitone name on some low end home electronics products and auto radios into the 50s.
Old 01-26-2007, 08:53 PM
I am replacing all electrolytic and paper caps, including the boost to B+ one.
One question is the rating for this cap. The Sams and the Philco manual indicate 400 or so volts. I am using a 600 volt replacement. One of my friends indicated that this should even be higher.
In the vertical circuit, there is a 1000 volt cap, I have been replacing this with 5000 volt ones that I have. I am aware that this is an overkill, but these are the only caps of that value with a voltage rating above 1000 volts that I presently have. I could wire two caps in series to double the voltage rating, but have not done this yet.
Old 01-27-2007, 12:34 PM
Ex-Philco
The boost to B+ cap will be OK with 400-600 volts. The boost on that TV is about 350 DC and the cap returns to B+ so it sees about 150 volts or so plus some AC. I recommend 600 volts, if you have them. Higher voltage caps in that circuit should not be necessary.
The vertical output plate feedback should be 1000-1500 volts rating. I would use a tubular, not a ceramic disc. That sees some big spikes and will affect the vertical frequency. Discs will likely cause drift.
Old 01-27-2007, 01:58 PM
I am using a tubular capacitor in the vertical feedback.
After looking at the 5 TVs that I am going to try to restore, I noticed one of them is called a "New Matic" not Seventeener. It has only a handle on top, no antennas. A single antenna comes out the side of the TV. It is a briefcase style TV.
I am aware that Philco produce some kind of squeese bulb channel changer about this time, but if this set had one, it is long gone.
Old 01-27-2007, 02:37 PM
Ex-Philco
Right. The new-matic was a later version that used a squeeze-bulb and a small piston and rachet wheel on the back of the tuner. The single rod antenna indicates a lower cost version. The handle-antenna was expensive to build because it had so many parts. It was clever since it was directly connected without wire, making it was shock and fire proof.
There were several TV derivations to provide varied packages for the dealer network. Independent dealers could offer a different version than department stores and Firestone stores to prevent shoppers from making direct price comparisons. Unlike cars, new TVs were rolled out every six months so the manufacturers strained for product differentiation.
