Old 09-20-2005, 02:25 PM
jonnic
Guest
Posts: n/a
Zenith and Philco 25" consoles
The same guy who gave me the Zenith Chroma color also has 2 25" console tvs to give away. One is a Zenith made June 1998. It is in perfect condition,still has the paperwork. I think it has a loose connection. The picture will shrink in the middle with black at the top and bottom. If you hit it it will clear up. Is that the bad crt period? He said it had a great picture other than that problem. The other one is a Philco XR series made Sept. 1985. It is also in very good shape. I dont know anything about how well it works. Are these worth getting? I know they are not real old. If I could get them going maybe I could sell them.
John
Old 09-20-2005, 02:50 PM
swanson
Guest
Posts: n/a
Sounds like the solder connections on the vertical sweep chip
are bad.Going in there and re-soldering the chip connections
should fix it.You may want to have a look at the connections
on the other components in the vert. sweep section also.
Regards,
Swanson
