CTC-40? on eBay
Out here in So Cal.
I was thinking about buying it so I could convert it into a condo and rent it for $1500 a month :rofl: http://cgi.ebay.com/Vintage-RCA-Colo...QQcmdZViewItem |
Yep, -40 looks right to me. This is VERY close to Tony V's. You could buy it, then have a contest to see who can get the color working first! Personally my experience is limited, but these sets are not junk.
Bryan |
Yep...Its a CTC40. Its identical to mine. Like Bryan said these sets arent junk and will more than do the job if your looking for an all in one. The FM tuner in mine is the best i've seen for picking up stations and the sound quality on the whole unit is pretty good. It even has an aux input in the back if you want to add a CD player. Huge...yes...heavy.....hell yes! Believe it or not it doesnt take up anymore space than your average entertainment center cabinet and of course its not as tall either so it appears less bulky in person. All in all a good unit. By the way Bryan...i got the chassis pulled now so i'll give you guys an update once i check it over and see if theres anything obvious. I'm keeping my fingers crossed that its something simple.
-Tony |
Many RCA techs consider the CTC 40 as one of RCA's best efforts. Good luck!
In the years that I did RCA/Zenith service, I think I worked on one or two CTC-40's. One, I vividly remember had problems blowing the trace SCR once in awhile. Its owner never had a problem with me keeping it for over a month since I was not the first shop to work on it. I found an intermittent connection in the hz drive circuit totally by accident, and never saw the set again. I know it is still running.
