Ok, we can get the jokes out of the way, why bother fixing the boat anchor, None of them ever worked out of the box, etc. I am doing a favor for a friend who knows that shipping it cost more than the tv is worth. It has sentimental value. After I give it a warm-up 15 minutes Everything looks ok, just ok. The focus is not perfect nor can I find any focus adjustment, be it a moveable wire or a pot. I do have the Sams for this model. Then while I am watching it, sometimes when the scene changes I get a blue band accross the screen next screen cut and it's back to "normal" for this set. The CRT is original, 43 week of 1968 and does not have a brightner. In order to get something resembling flesh tones I have to turn the tint control all the way clockwise. I did some tube tapping and could only find one that was noisey, sprayed the contacts and that problem went away. The Owner of this set is a very good friend of mine and I am ready to find a shop to rip me off. Some of the tubes have been replaced. I no longer have an oscilloscope or vectorscope(aren't friends great, I promise I will bring it right back) I am thinking of just start replacing caps in the video,demod, and chroma sections. Thanks To All For Reading My Rant.
Richard D |
No need to apologise-my folks had a Porta-Potty from '66 til we got the 1st Sony Trinitron in '72. Little guy was a trooper. Terrible picture unless the signal was REAL good. Would get hot as a firecracker, but IIRC, we never did a THING to it, until the very last, & then it seemed to have fifty-eleven things go wrong w/it. People laff at 'em now, but they were kinda Somethin' Special back in '66-a more-or-less TRULY portable color TV. Ours was on prolly something like 14-18 hrs a day, 7 days. I think all the while it had been fed 130volts-we're 5 miles away from a TVA generating plant, & you tend to get lots of "extra juice"...-Sandy G.
The set has an inconsistent black level which vary with the programme. In the first time I adjust brightness every time when the camera changes the scene until I found that there is no black level automatic in this set. |
I have a scan of a service manual to a portacolor if you need it. It's a more recent model than yours which uses a different CRT that has a focus pot, but otherwise it should be the same. You should be able to improve things a lot by doing a proper gray scale adjustment and changing the focus tap to the bes setting. These sets are always wayyyyyy out of adjustment when I get them. Don't expect a perfect picture. These always produce a washed out blurry picture. Be sure to replce the big ceramic cap near the horizontal output tube.
