Old 11-17-2022, 07:58 PM
Dave A's Avatar
Dave A Dave A is online now
Phlco 50T-701
I have a Philco 50-T701 with Horz problems. All recapped but it takes 20 min or so to H lock. H lock seems to be an automatic scheme. Always near the end of the range. Any suggestions?
Old 12-06-2022, 11:45 AM
TV-collector's Avatar
TV-collector TV-collector is offline
Hi Dave,
If it takes so long until the set works, I should search for a bad tube.
If the set is completly recapped, the next step will be troubleshooting for
a bad resistor.
Measure the right voltages to control the horizontal stage when the set is just
switched on.
Than check again after 20 minutes.
This could guide you!
Good luck!
Regards,
TV-collector
Scotty, beam me up, there is no more 4/3 Television and AM radio in Germany!
