Old 11-27-2019, 03:13 PM
Red Raster's Avatar
Red Raster Red Raster is offline
I Have a RCA CTC53A and am looking for schemaic
I have a CTC 53A in very good condition and I am looking for a diagram.
it is also in the Canadian RCC manuals #143.
Thanks.
Old 11-27-2019, 08:51 PM
It is in Sams 1201-1. Try to get a freebee first. If you cant PM me.
I should have it for sale MUCH less than Sams. It will be an original
high Q paper copy not a crappy PDF or Xerox.
These are tube hungry sets. If it has a good jug they can throw a nice
pix BUT you need a really strong jug. They were low focus CRT,s....
Old 11-28-2019, 04:05 PM
Red Raster's Avatar
Thanks Zeno,
I will give that lead a try,
My set has a real good CRT also I do have a new 24LQ6 amongst my tube stock
and the horizontal efficiency coil is in great shape (offten they are burnt to crispy critters).
Old 11-29-2019, 02:47 AM
ronl ronl is offline
Hi Red Raster. i do have rcc manual #143 but i dont see your set or in any index book i have. are you sure about that chassis# or book#?
RonL
Old 11-29-2019, 11:28 AM
Red Raster's Avatar
oops! my bad that should be RCC 134
Old 11-29-2019, 01:12 PM
Originally Posted by Red Raster View Post
Thanks Zeno,
That chassis doesn't use a 24LQ6. It uses either a 31LQ6 or a 36MC6!
Old 11-29-2019, 06:16 PM
Not sure it doesnt Dj. 36MC6 used in later hybrids IIRC. There was a 14" & 19" all tube. IIRC the 14" used a plug in damper diode that went often & the 19" a tube. IIRC there was a differance in HV regs. also.. May explain the 24 or 31
filaments. One thing I know is ALL of them used those lousy 5GH8's. Always
have a sleeve ready when working on one !
Old 11-30-2019, 10:48 AM
The chassis you're thinking of are the CTC22,36, the earlier hybrids. The 22 used the damper diode, where the 36 used a 6 volt damper tube with the heater working off the transformer that furnished the heater voltage for the CRT. I also remember the HV regulator tube in the chassis.
The CTC51,53 used 450ma series tube and not as many 6GH8's. The IF strips and audio circuits are solid state.
