Old 11-14-2017, 07:25 PM
benman94's Avatar
benman94 benman94 is offline
Resident Lunatic
Question about 15GP22 production
Does anyone have concrete information as to when exactly commercial production of the 15GP22 began, and when it ended?
I know the developmental tubes in the Model 5s were built starting in November of 1953. I'm assuming commercial production of the 15GP22 started in late December 1953 or early January of 1954, and probably lasted maybe six-ish months at most? And about when was hand welding of the ultor flange abandon in favour of automated welding?
My good 15GP22 was manufactured the 13th week of 1954; I'm trying to determine if this tube was hand or machine welded.
Old 11-14-2017, 08:16 PM
miniman82's Avatar
First Light: 1952-2011
Answer: both, not that it matters.
Even a ‘machine’ weld in those days was still a manually controlled TIG weld, and any holes found by the leak detector would have to be fixed by hand.
Evolution...
Old 11-15-2017, 10:43 AM
benman94's Avatar
Resident Lunatic
Thanks Nick. Bob mentioned to me that the later 15Gs seem to have a lower leak rate in his opinion.
Does anyone know when production started and stopped? I'm more interested in knowing how long the tube was actually built.
Old 11-15-2017, 11:17 AM
My 1964 Allied still listed a 15GP22 for $222.00. IDK, if it was NOS or recently manufactured.
The newest type listed was a 21FBP22.
Old 11-18-2017, 10:44 PM
Pete Deksnis's Avatar
15GP22 demo @ ETF 2007
Ben, the oldest 15GP22 I know of has a date code for the fourth week of 1954.
Pete
Old 11-18-2017, 11:05 PM
benman94's Avatar
Resident Lunatic
Pete
That's a bit younger than I was expecting. Thanks Pete.
It kind of pokes a hole in the hypothesis that the Admiral set was the first commercially available color set: Admiral would not have been selling sets with prototype jugs to the public, and if the oldest known production 15GP22 is from the fourth week of 1954, then nobody could have commercially released a set before then. You've gotta have CRTs to put in 'em...
Old 04-02-2018, 11:28 PM
wkand's Avatar
wkand wkand is offline
I have a 1965 Allied catalog that does NOT list a 15GP22 in its CRT pages. That might be one indication of when new or rebuilt 15G's stopped becoming available.
Old 11-19-2017, 12:53 PM
Maybe this is the back-end of the puzzle. Link to the graphic on my site of the only 15GP22 date code I know of that is not from 1954; it is from 1959 (in case the link doesn't work).
http://www.earlytelevision.org/Deksn...926-15GP22.jpg
Pete
Old 11-19-2017, 01:00 PM
benman94's Avatar
Resident Lunatic
Pete
Makes one wonder if it was a rebuild, or if the 15GP22 was still being manufactured new?
I figure RCA had built four or five thousand CT-100s, then there were the other 15 inchers (at least 500 Westinghouse sets, 100-200 GEs, etc) and finally all the studio monitors. There would have been some demand for 15GP22s into at least the 1960s. Probably not that great of one, but a real demand nonetheless.
Old 11-19-2017, 01:17 PM
My feeling always was that it was new. Or, perhaps assembled from a pile of parts held in storage for years...?
Old 11-19-2017, 01:23 PM
benman94's Avatar
Resident Lunatic
I think there are two plausible explanations:
The datecode is a misprint and it should be 1954, or the tube was manufactured new in 1959. The 15GP22 is on price sheets well into the late 1960s and early 1970s. Warehousing a bunch of product is expensive. It's possible that RCA kepts parts around to "build" new 15GP22s on demand for a while. They wouldn't be the first company to do something like that...
If it was a rebuild you'd expect to see a label saying that the envelope was reused and the tube was rebuild. I've seen an RCA rebuilt 15G with such a label, and I've never seen a rebuilt tube without a label clearly identifying it as such.
I think your gut feeling is right Pete.
Old 11-19-2017, 02:39 PM
Olorin67 Olorin67 is offline
i suspect they may have kept in production a while for studio montor use.. since 21" tubes might be a little big for that purpose. Were there any other smaller tubes available for when a 21" might be too bulky?
Old 11-19-2017, 07:19 PM
Dave A's Avatar
Dave A Dave A is offline
Just my opinion. The whole 15GP22 production was so crude with the flat plate, early phosphoring, physical alignment, welds, glass to metal, etc., It had to be low production and the 21 series blew that out of the water to the bean counters. I cannot imagine RCA kept that assembly line around for long. As for studio monitors it was a quick jump to jeeped up 21CT55 sets as many photos document. I think the ones on Allied, etc. were happily gassing away in loneliness on the shelves.
Old 01-18-2018, 01:57 AM
ohohyodafarted's Avatar
Bob Galanter
Dave I believe you are right on the money about the length of time RCA would have kept the 15G production line.
It is my belief that RCA probably manufactured a certain amount of surplus for replacement tube warehouse inventory. In addition, tubes that were in the field and replaced due to low emission, which were still holding good vacuum, could have been a source of candidates for re-gunning at RCA after the original production inventory run had been depleted. I believe someone posted that they actually had seen a 15G with a sticker that stated it was a rebuilt tube. So that confirms that RCA actually did rebuild some 15G's.
ME http://AntiqueTvGuy.com
Old 02-15-2018, 07:39 PM
vts1134's Avatar
vts1134 vts1134 is offline
Looking For Time
One of my 15GP22's has a 1959 date code.
John
