A depression era 4-tube "Auburn" cathedral
If anyone has any information on this set I'd appreciate it. It's a medium sized 4-tube cathedral radio from circa 1931. It has the typical unmarked shallow chassis and Rola speaker. Likely when I do research on it I'll find the same cabinet with a slew of different names. I like the deco "AUBURN" name on this one. This example was found in nearly mint original condition with a clean chassis and a globe tube still in place. I didn't check under the chassis, but it plays perfectly as-is with a long antenna. These lower-cost radios are classic relics of the depression and appealed to those on a budget at the time!
That looks a lot like my cathedral radio I have which was made by the United States Radio and Television Company of Marion, Indiana, which was aptly called U.S. Gloritone on the front of the Brass Bezel, and mine dates from about 1931 as well. Mine however wasn't in mint condition and needs to be restored, the previous owner of the unit put his hand through the speaker and the grille cloth which I was already able to repair the speaker using unbleached coffee filter paper and diluted elmer's glue, but I still need to refinish the solid walnut cabinet and get some new grille cloth for the speaker. By the way, my radio has a Utah speaker in it which sounds really nice for how old it is.
My unit thankfully was already electronically restored already but the person who did the restoration work on the electronics must of been somewhat of an amateur who was still learning seeing as he was stupid enough to put his hand through the speaker by mishandling the radio (he grabbed the radio with one hand by the top of the radio and the radio slipped in his hand and when he went to regrab it his hand ended up in the speaker). But either way at least the repair was fairly simple and the damage wasn't any worse than it was. Mine is AM Only with a frequency spread of 550-1650kC and I was able to pick up a lot of stations on it with just a 3 foot length of speaker wire that had been made into an antenna by the prevoius owner. Also do you have a picture of the guts of your radio? Just curious because after looking over the front bezel/knob arrangement and even the tuning dial on yours its exactly like mine except different name on the bezel and the bezel on yours isn't as ornate as mine is, other than that its is an exact copy of what mine looks like. Are you sure yours doesn't actually have 5 tubes in it? Because on mine they had 3 tubes hiding under a rather large shield cover and then the output tube and the rectifier tube are sitting on the chassis above where the power cord goes into the radio out in the open, if your radio's chassis is indeed an exact match to mine (like I think it is based upon the appearance of the dial/bezel and knob layout) it would actually be a 5 tube cold chassis set. Last edited by ZenithDude88; 06-18-2017 at 08:13 PM. |
It seems my set is unrestored or maybe service was done a long time ago on it. The set was such a clean original that I didn't even bother to remove the chassis when I got it to peak under the chassis. Last edited by decojoe67; 06-19-2017 at 07:09 AM. |
These guys typically ALWAYS do better than expoected ... OK. , so it AIN'T an R-390A, & won't pull in Radio Nibi-Nibi at high noon here in Greater downtown Bugtussle., but my example is a pre-war Arvin 2 tuber... Its 80 yrs old, , & if whoever gets it after I'm gone will give it just a tiny bit of TLC now & then, betcha it'll still be "Radioing" nearly 100 yrs from now...
Benevolent Despot |
They're analogous to a Porta Potty TV... GE came out w/them in late 1965. They were the 1st PORTABLE color TV. They took out anything/.everything that wasn't absolutely necessary to the receipt/display of a color signal. & GE was able to sell 'em for right at $200. My Dad got one of the 1st ones in NE Tennessee. It :"Lived" til 1973, on virtually 20 hrs a day .In that time, I think it only needed 2-4 tubes.NOBODY told Porta-Potties that they were cheap & nasty, so they typically just kept working. I dunno what ever happened to ours-My Dad might have sold/gave it away. It could easily be stuffed in a junk hole closet somewhere, awaiting its turn to be given a new lease on life....
Benevolent Despot |
