Old 04-15-2016, 07:34 PM
Radiotronman's Avatar
Radiotronman Radiotronman is offline
1968 Westinghouse JetLine
My neighbor gave me this 1968 Westinghouse JetLine tv. It keeps blowing the fuse attached to the line and the power transformer. I'm not used to working on these transistor sets, any idea what's causing his?
Old 04-15-2016, 07:40 PM
Here is the photo of the chassis. It uses a 19CMP4 crt. I don't have the schematic for this set yet. Has anyone worked on one if these sets?
Old 04-16-2016, 09:28 AM
I never knew they made that set solid-state. It was toward the end of Westinghouse's TV production. Looks overbuilt!
I had one, about two years older, all tube. Hot chassis, voltage doubler, probably TOTL and a great performer. Seemed to be a low hours set, CRT perfect!
Old 04-16-2016, 10:18 AM
The gig filter sounds like a real innovation.
Wunner if they had a patent on it.
Old 04-16-2016, 10:43 AM
Sorry guts, dang autocorrect! I meant fogged or smoked plastic screen cover.
Old 04-16-2016, 04:33 PM
The "sun screen" made the set look like it wasnt a TV when
off. It was like magic when you turned it on & a bright
picture appeared.
Tube models were more common but still not every day sets.
This was a big $ set.
W was about to pull the plug on consumer electronics at this time.
Personally I hated them but this is IMHO is a milestone set.
W had the ability to build very hi tec stuff but CE was a $$ looser.
IIRC they built the camera that showed N. Armstrong stepping
on the moon.
Old 04-15-2016, 09:10 PM
maxhifi's Avatar
maxhifi maxhifi is offline
There's a short somewhere.. Try a variac ?
That is a very stylish tv, what a cool find!
Old 04-15-2016, 09:29 PM
I did a continuity check on the electrolytics to see if any of them are shorted and I get continuity on several. This could be my problem... I'll order replacements and restuff them and see if I get any success. It seems odd though that a set this late would have that many bad, but I guess it is 50+ years old.
Old 04-15-2016, 10:39 PM
slowly bringing it up on a variac and I finally am seeing some life at about 40%.
Old 04-15-2016, 10:58 PM
What amperage rating are the fuses you're putting in?
Old 04-15-2016, 11:14 PM
Found a silicon diode in the hv supply get hot at 30%, so I replaced it with a new one and replaced the hv rectifier. The set works great now!
Old 04-16-2016, 12:01 AM
Popester's Avatar
Popester Popester is offline
CRT looks like it has weak emission. Not to bad otherwise.
Old 04-16-2016, 05:48 PM
David Roper's Avatar
console lover
Is that Dorothy Fuldheim with Johnny?
Old 04-26-2016, 10:35 AM
KentTeffeteller's Avatar
Gimpus Stereophilus!
Zeno,
Interested in why you aren't a fan of W television sets. And your experience with their repair and servicing perspectives. Your thoughts, please.
Old 04-26-2016, 01:09 PM
Originally Posted by KentTeffeteller View Post
Zeno,
Part of it was there were not a lot of them so never got used to them.
The color chassis was a bit cheaply made & messy looking. Also
very tube hungry sets. B&W's were better but many suffered from
slipping tuner wafers & yokes. Hard to describe but they always
seemed to be missing "something" like an Emerson or GE
with a few years on it.
And the owner hated them to. Had one someone got for free.
Great cabinet but high miles. He begged here NOT to fix it but she
could only see the cabinet. Took a bunch of tubes then she pulled
the old "my husband has the check book" scam. A week later
the FBT burned up & she wouldnt buy one. Never got a dime from the
bitch. A few yrs later at another shop I sold her a bottom line GE
range. I told her it only had one rack. 2 days later she was in
screaming for a free rack. I told her to call GE, it was hers.
She was really pissed off but I got some vengence for the W TV
screwing. They see & hear what they want to not the facts.
