1950 RCA 6t65 Highland console
Well another freeby followed me home. Looks to be in pretty good cosmetic condition, no major scratches and looks 100% complete. Cant wait to pull the back panel and check out the chassis.
From what ive read, this is the 6t65 "Highland" console with the kcs47a chassis, 16" tube. Hopefully it will be an easy restoration, since I want to have this baby in my house by winter.
"Good morning whiskey, good morning night. The end of the world is in my sight." Hank 3 |
Nice looking console in great condition. That'll be a great player when restored.
Hi, I have that set too. It was my great grandmas first set. If I remember right, that is a metal coned tube, so be careful because the whole cone is the second anode!
Very nice looking set, good luck with it.
Gregb |
Those sets......are usually never an easy restoration. At least not the few I've worked on. That one's usually a challenge. Hopefully the power transformer is original, there were a lot of cheapo power transformers installed in KCS47 chassis sets back in the day.
"Restoring a tube TV is like going to war. A color one is like a land war in Asia." |
I had this EXACT set for my first vintage TV. Since I did not know anything about them at that point, Kamakiri gave it a shot for me. Turns out mine was completely fried, and these chassis were not the best quality produced by RCA in the 1950s. Hope yours is in good shape and restorable. Tim used what he could from mine in parts and the rest unfortunately found the junkyard.
-Al |
Thanks for the tips everyone.
Well EVEN IF everything is shot, its a nice cabinet and could receive the internals from a more modern color crt tv. Then see what pieces of the chassis can be used by other restorers. I will be crossing my fingers that she is restorable
Do you have a CRT tester? IMHO, metal tubes are more likely to leak and die than all glass tubes. A 16GP4 may be pretty tough to find. If the tube is good or a replacement can be found, go for it ... you will likely increase your troubleshooting skills as well as your vocabulary of cuss words.
Very pretty set, worth the effort.jr |
Worse than that, I was about to recommend a 24" HDTV... decent fit since the mask for the nearly flat 16GP4 should fit pretty well up against the flat screen, height should be about right (11.5 inches) and only about 2 inches of width will be lost on either side when the set is in 16:9 mode. Much better, of course if the HDTV is in 4:3 mode (about 15.3inch width).
jr |
I have a similar set , in a slightly plainer mahogany cabinet. Got it free at a garage sale years ago. Tube is good in mine. Gets a raster, but thats as far as my efforts have gotten. Has sync, contrast, and sound issues. i think mine has a 16AP4 in it.
Well this has the 16gp4 crt in it. I have access to a crt tester, but its missing some of the plug adapters, so I will have to find out if i can test this.
When I opened the back, the missing power cord was wrapped around the crt. As well as a strange alligator clip that was clipped to the copper piece that goes between the HV cage and tube. Clipped to the chassis. Perhaps this set died, someone attempted a repair and gave up. ![]() and yeah, if the tube and chassis ARE dead, why not give away the pieces to restorers who can use it to get their sets back up and running? Better to modernize the internals, than to let a beautiful empty case go to waste and sit, maybe forever.
Luckily we both collect different things, so maybe she cuts me some slack on the kitchen deal.Anyway, that alligator clip you mention sounds like it was clipped to the rigid wire that presses against the side of the CRT to discharge the high voltage from the CRT during service. That bare wire is actually part of the HV circuit as much as any other wire. There is conductive paint on the CRT called agadag (spelling?) and the sprung wire must touch the CRT surface to complete the circuit. Always make sure that is touching the rougher aquadag surface and not just glass where a hole has formed. I have similar RCAs, but a bit older. Mine are 8T-243 and TC-127. Only the 127 I have gotten back to playable. I replaced all the electrolytic and paper/foil capacitors and a few resistors. I have vertical shrinking at the top, but the set is very stable with a really sharp picture. That vintage RCA was known for really good picture quality from all I have read or seen. My experiences with the two I have compels me to say that you MUST replace the power supply electroytic capacitors before bothering with anything else besides checking that CRT. My 243 was frying 5U4 rectifiers in a New York minute. I had to buy a replacement power transformer for the 127 and my belief is that someone at some point was determined to get life out of the set and simply fried the tranny by leaving it on for a while. You don't want to replace that power transformer! On top of that; your power supply is the heart and soul of the set. You want and need stability there so you can safely see what else is going on. Slow starting never hurts, and if done right can allow you to reform many capacitors after you stabilize your power supply. Even if you have already applied full AC wall current to the set for a bit, you can go back and let the set 'simmer' at say 50v for a few hours and work your way up in maybe 15v increments. Even after DC or B+ kicks in and you end up finally seeing what the set will or wont do, you will find that the longer you let it work the better it performs. The old caps can take a long time to do what they need to do. Just carefully feel the caps and make sure nothing is getting hot. If it gets hot; replace it. And does the octal plug have anything to do with sound? I can't remember how my speaker plugged in. I would say a normal speaker plug...
"Face piles of trials with smiles, for it riles them to believe that you perceive the web they weave, and keep on thinking free" Last edited by Tubejunke; 08-05-2015 at 02:30 AM. |
jr |
Oops! That's exactly what my Sylvania tube data book says. I had a DuMont once with a 19AP4 metal/glass CRT. Neat engineering concept bonding metal and glass like that, but the shock hazard is incredibly high. Mine had a rubber boot around the bell of the tube and a big warning label. The boot of course lent some comfort and protection, but I just made it a point to stay away from that tube; especially powered up!
"Face piles of trials with smiles, for it riles them to believe that you perceive the web they weave, and keep on thinking free" |
