Old 11-05-2004, 08:07 PM
asynchronousman's Avatar
asynchronousman asynchronousman is offline
Banned
Exclamation N-P 7" with tubes and issues
~7" National Panasonic AN-609D tubed "Speed-O-Vision"
Everything's there, nothing missing, CLEAN as a whistle, nice blue cabinet, Great CRT, audio okay, tubes light, screen shade present and set runs. I would guess around 1969 to 1971. A really neat portable in the vein of Froot-a-loop(?) and the portable 8-tracks they made in the 70s
Problems are thus: tubes glow red, flips, diagonal lines some times, tuning tricky.
Biggest problem: those three-so red tubes that are always on and put out decent sized heat! This may be a quick on set but I don't believe that's normal or good. It was removed from usage and won't be back until I can assure myself it's safe to use.
Any data and ideas are welcome.
Steven
Old 11-05-2004, 10:15 PM
Charlie's Avatar
Charlie Charlie is offline
On Land
Wow that's hot!
You're speaking of the filaments being too bright? Need to jerk those tubes and take a voltage reading at the filaments' pin sockets. If there is one winding in the power transformer that operates the heaters of only those three tubes, that winding may have a short.
Normally, instant-on sets only keep partial power on the filaments while the set is off... just enough juice to keep them warm.
Charlie Trahan
Old 11-05-2004, 11:34 PM
Banned
I just received my EICO model 221 a scant 4 daze ago...I haven't even had time to search for a manual to download much less figure all the probes!
Looks like if the chief engineer of KSRV is back, I should give him a call. I had suspicions there was something open. I am trying to learn how to fix my own stuff, and I also have a Coyne/Sams troubleshooting book I got from bgadow, but no soldering iron yet.
Old 11-06-2004, 07:48 PM
tv beta guy
Guest
Posts: n/a
I have one of those "Speed-O-Vision" sets in a white cabinet. Except mine has the model #AN-142 (anyone have an idea what year?) and is a 12". It is an instant on set (I guess that's why they called it Speed-O-Vision). All the tubes in mine are lit when the main power switch is off, but at a reduced voltage. It doesn't produce that much heat when off, but should not be glowing red. The TV used to work when I got it over 4 years ago, but it took almost 2 minutes of warmup time to get HV and horizontal deflection. The HOT was a GE replacement. Now all I get is audio, so that tube is shot. Other than that it worked well. I need to work on that set still.
Old 11-06-2004, 08:14 PM
Banned
Mine warms up then the picture screws up and it really won't tune too easily after that (needs spraying too).
But still, a pretty neat little set!
Old 11-25-2004, 08:37 AM
Banned
I've found another Speed-O-Vision model with different HV trouble (I think he was describing arcing). Maybe the two can get together and fix mine...
