Old 01-09-2015, 05:53 PM
mcmlxv's Avatar
mcmlxv mcmlxv is offline
1965 Westinghouse Attache Twelve NIB
I just picked up this Westinghouse portable. It's from the estate of a Sears sales rep. The set was made in Japan and contains an interesting mix of USA-made WH and Japan-made Hitachi tubes date coded 1965. The CRT is Mitsubishi-built. The set has a nice picture, and the little speaker really performs.
The set was found new, sealed in its box. The picture it's producing below is a YouTube feed from my computer. No amount of adjustment eliminates the distortion on the right side of the screen. But I'm leaving I alone. The issue isn't so bad that I want to compromise its originality. And boy does it run hot.
[ATTACH]185358[ATTACH]
WP_20150109_009.jpg[/ATTACH]
We think it's a better way to build television.
Old 01-09-2015, 06:16 PM
dishdude's Avatar
dishdude dishdude is offline
Now that is a cool find!
Old 01-09-2015, 07:27 PM
magnasonic66's Avatar
magnasonic66 magnasonic66 is offline
That is so cool!! It even picks up old TV broadcasts, Gloria Swanson on To Tell The Truth!
Old 01-09-2015, 08:05 PM
Neat set! I guess by the mid 60's they changed their slogan to "You can't be sure if its REALLY a Westinghouse"...
Old 01-09-2015, 08:39 PM
mcmlxv's Avatar
I was surprised that it was Japan-made. I though WH offshored a little later. Even so, it's obvious Westinghouse was the dominant partner. The only evidence of Japanese parts is the Hitachi sun logo on some tubes and the three diamond Mitsu logo on the CRT label and yoke. The names of the parent companies are absent.
Old 01-10-2015, 10:17 AM
The set's Mitsubishi built.
IIRC, there was a manufacturing agreement between Westinghouse and Mitsubishi, even with the large electrical equipment line.
BTW, I wonder how many people younger than me can decipher Roman numerals. My year is MCMXLIV.
Old 01-10-2015, 12:05 PM
I have a Westinghouse pre-war table radio, that was built by Stromberg-Carlson. Even the paper caps are marked with their name.
Some of the refrigerator radios were built by Wells-Gardner.
Old 01-10-2015, 03:49 PM
MGA CRT & yoke probably all MGA built. I dont remember
seeing these, just the W built ones that looked the
same on the outside. Look for the three diamonds on
the main PCB. The set looks better built than the other Jap tube sets
so probably all MGA.
Old 01-14-2015, 06:34 PM
mcmlxv's Avatar
I just wanted to take a minute and thank everyone for their kind responses. I've put a few hours on the set over the last few days and I love it. I have it hooked up to a generic Chinese ATSC/NTSC converter that includes a USB port on the front panel. Using this box with an antenna, the picture fills the entire screen. I can also rip video files onto a USB thumb drive and watch that way too. Unfortunately, there's a significant buzz that I can't seem to eliminate. Any suggestions would be welcomed.
When I have more time, I'm going to dive deeper into the set and see if I can find any more markings that would clue me in to the manufacturer. I agree that it's probably Mitsubishi.
And Dieseljeep, I'm going with 1944.
Old 01-14-2015, 07:28 PM
You are so right, regarding my year of birth, December, 1944. Franklin Roosevelt was the President.
Old 01-14-2015, 08:28 PM
Never seen one witha USB port before, Sounds like an interesting converter box.
Old 01-16-2015, 02:37 PM
... Unfortunately, there's a significant buzz that I can't seem to eliminate.
Does that buzz get worse when there are bright white areas on the screen? If so, what is likely happening is that the set's IF strip is going into cutoff when the video carrier is at its lowest level (which happens at peak white). And maybe a tube, or some biasing circuit, is clipping the IF signal so it goes completely away. And in intercarrier sets, where the video IF beats against the sound IF at the video detector to get the 4.5MHz sound subcarrier. But if the video carrier disappears momentarily, the sound subcarrier also disappears. Which makes "holes" in the sound, thus the buzz.
One workaround is to reduce the amplitude of the video signal going into the RF modulator inside your ATSC converter box. This would allow a larger amount of carrier signal to be produced on peak white, and hopefully enough of the carrier reaches the set's video detector to avoid the holes in the sound subcarrier.
Or dig into the set's IF strip circuits.
Old 01-09-2015, 08:55 PM
Olorin67 Olorin67 is offline
I think a lot of companies that otherwise built their own sets started outsourcing small less profitable things like portables in the mid 60's. by the late 60's most 12" and under sets were imports I think.
Old 01-09-2015, 10:10 PM
It looks a little bit like this radio that looks a little like a TV set. The marketing dept must have been a wild place to work back then...
Old 01-09-2015, 10:18 PM
dishdude's Avatar
It does look like that funky clock radio! Was the Westinghouse TV and Radio division headquartered in Pittsburgh?
