Old 01-09-2015, 01:29 PM
Olorin67 Olorin67 is offline
B&w picture tubes, larger than 23"
Ive seen a number of 1950s tvs with 24 and even 27" picture tubes, but does anyone know if there were later large b&w tubes that were bigger than the 23" rectangular tubes that were nearly universal in 1960s consoles? All the references ive seen for larger tubes are the 1950s tubes with rounded corners, but there is a 1960s Setchell Carlson thats been on the Minneapolis Craiglist forever that claims to be a 27" but it has square corners like the later 23" tubes. Did they make 25" or 27" squared corner tubes? Or is that set just a 1950s style tube with a square cornered mask to make it look more modern?
Old 01-09-2015, 01:57 PM
Zenith26kc20's Avatar
I think Magnavox had a 27 inch BW that went into the 60's. I've never seen a BW tube with really square corners. DuMont had the biggest BW CRT at 30 inches but it was round.
Old 01-09-2015, 02:09 PM
We had a Maggy 27. Pre UHF mandate. The set only lasted about 4 yrs.
The OM went back to Zenith real fast !
Old 01-10-2015, 10:25 AM
I replaced a CRT in a 27" Magnavox 1965 model. The set was solid state, except the HV rectifier. They boasted that it was the first solid state large screen set, which it really was. It looked like their earlier models with the separate safety glass.
Old 01-09-2015, 02:41 PM
People on Craigsist often measuer the entire mask, or the edge of the cabinet, or the size of the room it's in and claim that as the CRT size. I can't recall anything larger than 27" with really square corners, if there was one it was probably a Magnavox.
The bigger tubes often seem to be bad, probably a combination of the large screen area and the high number of hours used during the 60's.
Old 01-09-2015, 03:23 PM
I don't recall any B/W crts larger than 23" (approx 21"/but with squared corners) that had the square corner shape. there were 24" and 27" sets offered in the waning days of B/W sets but IIRC, these had the more rounded corners like this spectacular Zenith 27 incher:
http://tvhistory.tv/252KA21A5.jpg
From TV history site.
Old 01-09-2015, 05:19 PM
IIRC, Admiral had a 25" B/W crt, as one of their last offerings. Probably made by National Video, with squared corners. They made a lot of strange model sets, hybrid B/W sets, with only a few odd-ball tubes for the sweep circuits.
Old 01-09-2015, 09:47 PM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
I've got one of the 27" Setchell Carlson sets, has a 27RP4. This particular one is an RCA Silverama replacement dated 1/65, and tests as new.
Old 01-10-2015, 01:06 PM
Interesting, Thanks for posting! I have never seen one, and my tube manuals (early-mid 60s) don't list any 25 inch P-4 (B/W) jugs. However, in a Sams pocket sized "Tube Substitution Handbook" 1972 printing, I found listings of 25DP4, 25HP4, 25JP4, 25KJP4, 25LP4, and 25TP4. With color TV rapidly gaining popularity in this time frame, I suspect that sales for these large screen B/W sets were rather poor.
Old 01-19-2015, 11:11 PM
Robert Grant's Avatar
Robert Grant Robert Grant is offline
Radiomuseum.org shows the 25LP4 and 25TP4 being used in several sets for the Australian market in the mid-to-late sixties (note that the market for big monochrome sets had not been displaced by color sets as Austrailan TV transmissions were still monochrome).
The 25DP4 and 25DP4 show up on frank.pocnet, with tube manual pages from Sylvania, from 1965. It's a bonded front tube, with the front about the same shape as the 25XP22, but a slightly larger picture than the 25XP22. I would be really curious to know what, if any, TV sets used this tube.
I must admit I have a weakness for big B&W sets, it dates back to my hobby of fixing discarded sets when I was a teenager. When I saw how much more complicated color TV sets were, I wondered why anyone would have wanted a color TV!
Old 01-09-2015, 04:43 PM
I know the CL set you're speaking of. I believe I have a very similar cabinet model and it's a 23 inch CRT. I think the one on CL has it's legs removed and appears to be hanging from the ceiling. Funny how that CL seller hasn't budged on his price in the (I think) 3 years I've been seeing it.
Old 01-10-2015, 10:42 AM
Marco-nix's Avatar
Marco-nix Marco-nix is offline
Hello Kevin,
I saw this " 1964 Zenith Model 5119 Color Roundy ". Is it possible to have it in pdf from you? thanks in advance..
Old 01-12-2015, 11:33 PM
I immagine the survival rate for big screen B&W sets was also low, they were too big to put in a den or bedroom once they were demoted from living room duty when they were replaced by color sets.
Old 01-13-2015, 12:10 AM
I found some listings in my 1969 GE tube manual. There are many 27" tubes listed, but most are the rounded corner,90 degree 1950s types. However, there is also 2 National Video tubes listed , with 1962 dates, that appear to be 110 degree square corner tubes. There is also a RCA data sheet from 1964 for a 24BEP4.
Old 01-20-2015, 07:29 PM
Reece's Avatar
Reece Reece is offline
Wasn't there a 30" Crosley in the fifties? As to the corners, I don't know.
Reece
