Old 07-06-2014, 07:44 PM
Bobby Dip Bobby Dip is offline
Horizontally Segmented Picture
My recently resurrected experimental Delco car TV, just developed a new problem. The picture is torn into horizontal segments that don't quite line up correctly. (See picture.) The number of segments continuously changes. This problem just suddenly started. The picture was fine previously. (The picture tube is an old 5AXP4 test CRT for now. The TV is B&W early 50s.)
I'm hoping that someone can identify the problem from these symptoms. I'm not a TV guru.
Bob D.
Old 07-06-2014, 08:03 PM
Possibly an open connection in the CRT socket. One of the lugs not making connection with the pin, and a little arc jumping the gap. Just a WAG.
Old 07-06-2014, 08:37 PM
I'd look for loose connections first, as stated. Not only the CRT, but check out the tube sockets in the vertical section. Wiggle tubes, tap gently in various places, and so forth. Also try wiggling vertical hold, height, vertical linearity controls.
Old 07-08-2014, 05:25 AM
earlyfilm's Avatar
Eternal Member
This looks to me like a vertical sweep problem, not a CRT one, although a loose and arcing connection almost anywhere could cause it.
The horizontal shift is probably from the collapsing vertical output tube changing the load on the flyback, assuming the vertical output tube uses B-boost from the damper tube.
It is hard to judge vertical linearity from this picture, however, with that said, it looks compressed at the top and stretched at the bottom.
Try substituting both vertical sweep tubes. If you don't have alternate vertical tubes, try tapping them gently and see if this changes the problem or you see internal sparking on the tube.
Visually inspect the vertical circuits for loose connections. If none are found try gently probing them with an insulated rod. Listen for the sound of arcing in the yoke assembly. You also can do this with an insulated tube for the rest of the set.
Note: The vertical output transformer may make a sound that matches this, if the plates are loose. To determine if this is a problem or not, tighten the screws slightly. If this reduces the sound, this is normal. If not, suspect an arcing transformer. (Smaller vertical output transformers don't have screws, just metal crimping.)
Have you replaced the grid coupling condenser between the vertical oscillator and the vertical output. If not, it could be breaking down.
A resistor (cathode, plate, grid bias) in the vertical output circuit could be breaking down. Check for changes in value.
If you are using the yoke that came with the Delco set, do a test with the one that came with the test tube. These are usually general purpose ones.
James
Old 07-08-2014, 05:58 AM
Giulio Maiocco's Avatar
Giulio Maiocco Giulio Maiocco is offline
Geloso prototype owner
Stupid question, but are the various parts of the image somewhat overlapping each other? If so, the problem may be spurious oscillations in the vertical section or maybe the horizontal pulses are coupled somewhere in an unwanted location in the TV set, rendering the vertical scan so "strange". If this is the case, I'm afraid, it's usually oscilloscope time
Cheers
Giulio
Edit: not exactly the same problem, but the image attached should clarify what I meant in my post
Old 07-08-2014, 09:05 AM
earlyfilm's Avatar
Eternal Member
Originally Posted by Giulio Maiocco View Post
. . . . . . the problem may be spurious oscillations in the vertical section . . . . . . .
Exactly!
What I think is happening here is electrically the same thing that motor-boating is to a vacuum tube audio power amplifier, and the same checks will usually work. In both cases, for pre-1960's equipment, it is most likely in the output stage, but can be anywhere in a related circuit.
The problem here is this Delco Auto TV is probably a proof of conception prototype, most likely made to determine if the public would buy one if GM offered a car TV for sale. This prototype only had to work well enough for display and there is no known documentation on the set, including what voltages the missing power supply provided.
Since this spurious signal is probably happening in the vertical output area, the scope will be of little use here. If Bob cannot localize the problem, he may have to find a TV restorer locally who has a scope and is familiar with the older vertical circuits, but that is the last resort.
Bob, I forgot to mention earlier, if there is an electrolytic across the cathode resister of the vertical output tube or in the plate circuit and/or screen grid of the vertical output, make sure they are good. This test can be made by simply jumping them with a second electrolytic, since over capacity here should not do any harm.
James
Edited to delete incorrect assumption. I incorrectly remembered that GM completely switched from subcontractors to made-in-house auto radios as 1953 or 1954.
Last edited by earlyfilm; 07-08-2014 at 10:34 PM. Reason: I think dieseljeep, below, is correct and I was wrong on GM change
Old 07-08-2014, 11:00 AM
Originally Posted by earlyfilm View Post
Exactly!
The problem here is this Delco Auto TV is probably a proof of conception prototype, most likely done to threaten GM's auto radio suppliers against overcharging for sets and/or to determine if the public would buy one if GM offered a car TV for sale. This prototype only had to work well enough for display and there is no known documentation on the set, including what voltages the missing power supply provided.
James
The General always built their own radio's since 1946.
All GM cars, with factory installed radio's, were Delco built.
Old 07-08-2014, 11:21 AM
Interesting. The unknown TV in my Scott 800B radio/TV/phono set recently developed exactly one horizontal fold similar to the ones you are seeing. My first thought (fear) was that something may be going wonky in its vertical output transformer. This discussion gives me some other ideas. It will be quite a while until I have a chance to wrestle this 200+ pound monster out for an exam, however, since I have other projects in the queue.
Phil Nelson
Phil's Old Radios
Old 07-08-2014, 10:39 PM
Problem found
The picture tube anode cable was broken internally. A quick resistance check showed no continuity. I made up a new cable with some HT wire I had on hand and now the picture is fine. The old cable must have been arcing across the break inside the wire.
I'd like to credit my trouble shooting technique, but the only reason I checked the cable was it looked really beat-up. Sometimes you get lucky
Thanks for all the good advice.
Bob D.
