On Tuners and UHF Mods/Adapters
Perhaps this is a fuitless pursuit, but I'm curious to know whether there is any surviving information on UHF tuner add-ons. By this I don't mean standalone UHF converter boxes, but rather the type that would have been sold as an optional "feature" of one's television set.
There's some interesting information in http://www.antiqueradio.org/art/RCAC...nerArticle.pdf which describes a combination VHF/UHF tuner and how they are two separate parts combined. The service data for my set even makes reference to an attachment point for a UHF signal in the tuner (http://vintagepc.site50.net/site/fle...ice/TV_004.png). Presumably if you went for the option when purchasing the set, your dealer could then install the additional tuning mechanism (for sets with separate knobs for each) and special UHF mixer strip in place of one of the VHF channels, and it would feed the output of the UHF tuner to your IF strip. My curiosity in how this works has me wondering if one could cobble together a functional UHF adapter in this same fashion with the correct reference literature. A schematic of an external converter could be of significant value since it would essentially be doing the same thing. Was the crude principle behind it (excluding tuning mechanics and such) simply to frequency-shift the UHF station down to VHF frequencies with a simple superheterodyne receiver, or is there more to it than that? Looking on a certain auction site the standalone ones seem deceptively simple with only one or two tubes. If shipping from the US wasn't often 2-3x the price of these I'd be tempted to pick one up just to see what the insides are like. Edit: I see a few BTC-99s floating around for a reasonable price. Are those any good? Is there service literature available? Last edited by VintagePC; 04-11-2014 at 11:39 AM. |
The only sets with strips I know of were Zeniths but never seen
any with them installed. If a tuner has a UHF IF jack just about any tuner will work. Just add B+ usually 12 V & antenna, ground the AFT if it has it. When you go to UHF the VHF RF amp & mixer are just turned into 2 more IF stages. All UHF tuners are cap tuned as far as I know. The RCA tuner is an odd ball, never seen anything like it. Some probably had add on kits but with the added costs I doubt many were sold. The set-top box is the easy way out. 73 Zeno
I remember, Zenith used strips, more than other firms. In the Neutrode tuners there was a separate set of contacts, just for the UHF antenna. I could go on and on about UHF tuners, as Milwaukee was a UHF town, from early 1953. |
Also... does anyone have comments on single-tube vs 2-tube UHF converter boxes? I heard folks say the 2 tube ones were better/less finicky, but does that still make a difference for signal quality if you feed it cable? |
Regarding: the set top convertors, the Blonder-Tongue and the Granco one tubers worked fairly well, the Regency's, not very well, if at all. The hottest two tube units seemed the Turner's and the Radio Receptors. I don't know how many different brand names that the Mallory's were sold as.
Alternately... there's probably no reason one couldn't fabricate a UHF channel strip with a 3d printer, a few small brads for the contacts, and some calculations to figure out what the coil inductance should be.... |
Philco sets had a center mounted (between the two chassis) UHF tuner that was available as a dealer add-on or factory installed. Early 1953 model shown here: http://www.videokarma.org/attachment...4&d=1291836085
I have seen some of the "kits" for this installation on eBay. jr |
Do they appear for sale often/cheap or are they much sought after by enthusiasts? I only see one at the moment. |
jr |
WOW! that's a really nice looking pair of Philcos! Interesting that they both have the slide-rule dial rather than the rotary style that both of mine have. I think that mine were both dealer installed... perhaps these are factory? I have also seen another style that is a slide-rule type, but the scale is tilted (prism perhaps), for better viewing from above.
jr |
I have this brown metal box set-top converter RCA made. Connects like the Blonder Tongue units but is much older, like the Mallory units with the slide rule tuner and glass dial
Its got two channels, selected by a large gold plastic knob. 3 positions; VHF, UHF1 and UHF2. It definetly uses strips, not a variable CAP tuner. Most of the towns (beyond fringe of 60 miles from Philly and Baltimore) here had exactly 2 channels, so this set up worked well. You likely could not get UHF more than 35 miles away, with the lower effective radiated power of these UHF's, which always shared call letters with the town's AM stations, in the early 50's. When power increased and antennas got better
"When resistors increase in value, they're worthless" -Dave G |
I have a 17" metal cabinet table model RCA 17T200 that has one installed on the right side, just behind and below the speaker. jr |
As always I'm fascinated by the amount of knowledge that folks here have. I have a UHF converter on order now and I should also be obtaining a 3D printer at some point in the future...
I do intend to take a crack at fabricating a UHF strip for my tuner (because why not? worst case it doesn't work, best case it does and may prove useful for folks wanting to do the same) and I'll be sure to make a thread here because I'm sure others will be interested in that too.
