Old 12-28-2011, 08:56 PM
Rinehart Rinehart is offline
Signal interference and the FCC license freeze
I would like to get some information about the FCC license/CP freeze from September 1948 to April 1952. The FCC instituted it because they were unaware of the problems of signal interference when they allocated frequencies for television licenses near the end of the war.
My question is: why did they make such a mistake? One of conditions of obtaining a television broadcast license, either experimental from 1936 or commercial from 1941, was that the licensee had to have an active research program on this very subject. Did the stations provide faulty or incomplete information to the FCC, supplemented by guesses, or were there factors that they could not have anticipated at the time?
Also, since a television signal was propagated line-of-sight and its range limited by the radio horizon (10-15% farther than the optical horizon) why was there interference between stations hundreds of miles apart?
One Ruthie At A Time
Old 12-28-2011, 10:24 PM
I believe that under certain conditions the transmissions in the VHF band can "skip" between the ionosphere and the earth like SW (sometimes called "world band") radio signals. I believe that prior to the war the only places where experimental broadcasts occurred in the US were NYC, Chicago, and LA. and I believe that most recievers were placed in the estimated good signal area of those stations. thus the full extent of the skip phenoninon was not able to be documented because no active recievers were present far enough away from the transmitters.
After the war there were many new stations and a comparative TON of new active recievers at all distances from the stations thus the FULL extent of the skip could be documented and recoreded. This new documentation I believe surpassed estimates based on previously documented info and led to the licensing freeze as the new info was analyzed.
This was a big headache for the FCC, but a big benefit for the TV mad public that bought and operated sets well outside of the estimated usable signal zone.
Old 12-29-2011, 05:14 PM
Yes, that seems a quite reasonable explanation--this had always been there, but it wasn't noticed until the rapid expansion of television after the war, and you feel that it was a good-faith error. According to the 1939 Broadcasting Yearbook, there were 23 licensed experimental stations as of November 1, 1938, some of which were in the large cities of the northeast, (7 altogether in NY, Philadelphia, Chicago, and LA,) and the rest scattered around the country, some of them in very unlikely places.
As of January 1946, there were 9 commercial stations and 26 experimental stations; by March 1947, 55 commercial and 63 experimental; by Jan 1948, 72 commercial and 91 experimental; at the time of the license freeze in September, 124 commercial stations (the Broadcasting Yearbook does not list experimental stations after the 1948 edition; all figures include construction permits granted.)
The FCC must have made an announcement on the subject, but when I looked through back issues of Billboard and Broadcasting Magazine I didn't see anything. If anyone knows where I might find it, please send me a PM.
Old 01-03-2012, 09:07 PM
NowhereMan 1966's Avatar
NowhereMan 1966 NowhereMan 1966 is offline
Slave to 1 Cat
I know here in Pittsburgh, we had WDTV on channel 3 which later became KDKA-TV and shifted to channel 2 because there was occasional interference with WNBK on channel 3 in Cleveland. We used to be with DuMont.
Mom (1938 - 2013) - RIP, I miss you
Spunky, (1999 - 2016) - RIP, pretty girl!
Rascal, (2007 - 2021) RIP, miss you very much
Last edited by NowhereMan 1966; 01-03-2012 at 09:12 PM. Reason: Corrected the (then) call letters of the Cleveland TV station
Old 01-04-2012, 01:02 PM
I always thought Pittsburgh was too far from Cleveland for such an interference problem to occur.
WNBK-TV in Cleveland (later KYW [1955-65] and now WKYC [1965 to present date]) started in 1948 on channel 4, so any interference problems would have been with channel 4 in Detroit, unless the latter signed on years after the Cleveland station.
I don't know when WNBK switched to channel 3; must have been before my time because, as long as I can remember, channel 3 has always been in Cleveland. (I am 55 years old and remember KYW, as well as when NBC purchased the station from Westinghouse in 1965 -- what a mess! Wikipedia has the full story on the Westinghouse-NBC fiasco in Cleveland, and believe me, it is very interesting reading).
Come to think of it, WNBK-TV on channel 4, and its switch to 3, was before my time, as the station had that call sign from 1948 until 1954.
BTW, the callsign WDTV, IIRC, is now held by the CBS TV affiliate in Weston, West Virginia. The station is on channel 5.
Old 01-04-2012, 09:59 PM
Slave to 1 Cat
Interesting story there, I plan to read it. I know Westinghouse also bought a Cleveland radio station as during that time and it swapped the KYW callsign from Philly to Cleveland. I know there were some times I did get channel 3 from Cleveland during the analogue days so I think interference could be possible. It looks like this was during the days when they though 12 VHF channels would be enough but they were wrong. IIRC, when UHF came about, Youngstown, OH became a UHF market with 21, 27 and 33.
Old 01-04-2012, 10:43 AM
electroking's Avatar
a- v- karma member
Because that is not always true! A search on the topic 'TV DX' will tell
you more about this.
P.S.: this reference is good reading about this topic.
http://en.wikipedia.org/wiki/TV_and_FM_DX
