Old 08-07-2011, 09:54 PM
charokeeroad's Avatar
charokeeroad charokeeroad is offline
John Q
My first Silvertone
I picked up this little Silvertone yesterday in LA. Don't have a model number and not sure of the year. Has the back and all the knobs and PB door. I did an internet search but couldn't find anything on it. Any input would be appreciated.
Old 08-08-2011, 09:04 AM
That set is a 1952/53 model. Sears used the same knobs and control door on several models. You need to show a chassis view to identify. Our family set was 21" console with the same knobs and control door. The chassis was made by Stewart-Warner. Your set might be a Pacific-Mercury. That was one of their suppliers on the west coast.
Old 08-08-2011, 06:11 PM
John Q
Thanks, I was able to find a silvertone set from 1953 with the same knobs so that helps identify the year. I'll need to get back home and take some decent pic of the chassis and measure the CRT.
Old 08-14-2011, 08:25 AM
John Q
Looked high and low for a model number. What I found was a catalog number 1299 and a chassis number. I measured the CRT from the outside cabinet glass diagonally it's 15 inches but it could be a 16 in CRT as there were very few 15" CRTs to look at in my testing book. There were no markings on the neck of the CRT. The end cap had a chunk missing but otherwise is intact. I tested the CRT and it has low emissions even after sitting for 20 minutes or so, infact the longer it sat the lower it went. I zapped it once and that helped momentarily but then it started to sink again. Anyone have a CRT that would work in this set that they are willing to part with? It's rectangular
Old 08-14-2011, 03:00 PM
WISCOJIM WISCOJIM is offline
Look for a number like 132.41000 or 569.32440200. (3 digits, decimal point, 5-8 more digits). Sears often used those types to identify sets, and a Sam's search may then find a match.
Old 08-15-2011, 10:13 PM
John Q
I found these numbers on a metal tag on the back of the chassis. 456.150-1,
Does that look like the model number? The chassis number is 47180.
Old 01-29-2012, 10:46 AM
John Q
I looked on the ETF site but didn't find the Riders or Sam's listed there so I'm asking Sam's to do a search for me. Using their search engine it didn't find anything on either the model number or the chassis number. I did find a very dereriated label on the back that has the date 1950 on it. So We'll see what Sam's search comes up with. I believe the chassis number to be 47180 and the model number to be 456-150-1.
After looking at the bottom of the chassis and seeing only 15 or 20 caps there I'm really tempted to try and do this one myself. The component arrangement is very open...what could go wrong?...
Old 01-29-2012, 11:30 AM
According to the code date on the original CRT, it shows 1952, 47th week. It must be the original CRT. Made by National Union. Also looks like a 17HP4, which wasn't out in 1950. I never saw a Pacific Mercury set in the midwest.
Old 08-15-2011, 10:50 PM
I believe 456-150.1 is the chassis number and it's covered in Riders vol 14.
Old 08-15-2011, 11:34 PM
Also found in Sam's Photofact #230-10 from February 1954.
Old 08-16-2011, 11:25 AM
John Q
Thanks I"ll check it out.
Old 01-23-2012, 07:39 AM
John Q
If someone would be so kind as to look at the info above and help me identify the CRT in this set I would appreicate it. I don't have any reference materials on hand. Also if some one has a good one I'm still looking for one.
Thanks
Old 01-23-2012, 12:40 PM
The Sams manual says 21MP4 (noting that some models may use 20HP4 or 20HP4A).
Phil Nelson
Old 01-23-2012, 01:16 PM
That set looks to me like a 17" set. Probably a 17HP4, or simular. The console pictured is a 20 or 21 inch model. They probably used that same chassis in 17, 20 and 21" models.
Old 01-28-2012, 06:23 PM
John Q
Good Eye!
