Old 05-05-2010, 04:18 PM
Almost a year since analog TV died
11 months actually. I suppose by now everyone has adjusted to having no over-the-air analog TV reception. And has either gotten converter boxes or new TV sets. Or given up TV or got cable or satellite.
Haven't heard of any analog pirate TV stations popping up in inner city areas. Those areas do seem to get a lot of pirate FM radio stations though.
Old 05-05-2010, 04:23 PM
I get a couple religious channel, one in english one in spainish. UHF and weak.
Old 05-05-2010, 04:26 PM
Zenith26kc20's Avatar
Thumbs down
Got four Digital Stream converter boxes. Unless the antenna (Channel Master 4251 with 7777 amplifier) is aimed fairly good, it will still pixil once and a while. DXing can be a PITA as the boxes need a fair amount of signal to make them work. 100 miles is now the usual maximum where before the transition, 150+ was fair game for the CM4251!
Better pictures!
better sound!
more channels!
Swamp land for sale!
And just think! The FCC wants to take MORE bandwidth away
Old 05-05-2010, 04:34 PM
Adam's Avatar
Adam Adam is offline
I check occasionally, but never seen any pirate stations. But I do still get Candian ch 9 up here.
I'm pretty well set up now with a converter box on ch5, and a dvd player on ch3 downstairs. Upstairs I have a dvd/vhs player hooked to one of those agile modulators which will give me chs 1-25.
Old 05-05-2010, 04:39 PM
ctc17 ctc17 is offline
Its Horrible!!
An outside directional antenna is a must.
The boxes ground loop and interfere with each other if they are connected to the same antenna.
Weather, reflections, cars and aircraft effect the signal and cause trash.
I dont like how almost everything is wide screen.
Small portables have been mostly rendered useless.
I adjusted by activating a direct tv receiver someone gave me.
Old 05-05-2010, 04:50 PM
I guess everyone in my area had adjusted. I don't hear much complaining, except the rare occasion where someone can't get good reception.
We had one low powered religious station on UHF; but, they went dark in February, due to lack of funds and the fact that not too many people were watching their OTA analog transmission. They are still on cable and satellite.
I have regular basic non-digital cable here; but, I have several DTV converter boxes for use with my old TV's and to have in case we end up dumping cable. The only set in the house that has a built in DTV tuner is my Mother's 26" Samsung flat screen.
I have one channel master box and two digitalstream boxes. Packed in the closet are a Magnavox (Funai) box and an Apex box. The Apex was free and I gave a guy $15 for the Magnavox once he discovered that he couldn't get crap out in the country using rabbit ears. The DS and CM boxes were bought new by me. I still would like to find a Zenith/Insignia box.
Old 05-05-2010, 07:26 PM
amptramp's Avatar
amptramp amptramp is offline
VK Member
We have analog TV. We have analog FM. It's good to be Canadian!
Old 05-05-2010, 07:49 PM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
I supose you will soon be going digital. It seems to be hapening all over the world. Even so, I bet it's still good to be Canadian. The US is getting nuts anymore.
Old 05-05-2010, 08:03 PM
"Small portables have been mostly rendered useless. "
I guess that I am lucky... we still have 2 useful (low power) analog stations, so my small collection of Sony Watchman sets still can be used around the area when needed. When analog totally disappears, I will rig up a modulator to feed these sets in the house.
DTV portables have improved in sensitivity also... In every room of my house (12 miles from the transmitter sites) I can usually tune the major channels on this little 3.5 inch set, using the built-in monopole antenna. They are still worthless in a moving vehicle, however.
Old 05-06-2010, 11:15 PM
Even with an external antenna that clips onto the rain gutter around the car's roof? These antennas were used quite a bit with the first battery portable TVs for mobile reception; they worked quite well in the stations' normal coverage areas, but then again all TV was analog in those days and the signals were a lot stronger. However, I don't see having a television in a moving car these days as a problem; after all, it is illegal to have a TV set in a vehicle where the driver can see it. This law has been in effect for decades, dating back at least to the days of the 5" Sony Micro TV which was, IIRC, one of the first transistorized televisions capable of operating from a 12-volt car cigarette lighter socket as well as its own batteries. Besides, IMHO, I don't honestly believe there is anything that interesting on OTA network TV these days (yes, even the evening news) that can't wait until the person gets home to watch it on his or her regular TV set.
Old 05-07-2010, 12:51 AM
A little extra strength can't hurt, but the problem really is related to the digital system that was selected for the US.
"ATSC is optimized for a fixed reception in the typical North American environment and uses 8VSB modulation. The ATSC transmission scheme is not robust enough against doppler shift and multipath radio interference in mobile environments, and is designed for highly directional fixed antennas."
Possibly, some modifications to the coding scheme will help.
"To overcome these issues, additional channel coding mechanisms are introduced in ATSC-M/H to protect the signal."
Quotes taken from:
http://en.wikipedia.org/wiki/ATSC-M/H
Old 05-12-2010, 03:27 PM
electroking's Avatar
a- v- karma member
Until August 31, 2011, that is!
By the way, everyone in North America (except maybe in deep rural areas)
still has analog FM!
Old 05-05-2010, 08:25 PM
I pulled out my old trusty 3.5" Panasonic B&W portable from '78, dug around and found a 3.5mm to "F" connector adapter, and connected it to cable and it works just fine. I could also use it with a DTV converter; but, I think the days of me loading it with batteries and taking it outside to watch are over. That little TV came in handy many times when we had power outages and bad weather. At least it has a fairly sensitive AM/FM radio that can still be used as a portable - that is until they decide to do away with that, too!
Old 05-05-2010, 08:46 PM
peverett peverett is offline
A strange thing happened here. For a while analog was completely dark. Now, after watching DTV over one of my analog sets using a converter, if I turn the converter off, a weak analog signal appears. I guess a low power analog station has turned on. I have not had a chance to investigate yet.
DTV works as it always has for me-ok in good weather, but garbage in poor weather. The most sorry thing for me is that this spectrum was essentially given the phone companies so they could charge us outrageous rent on it. Not the best use of a public asset in my opinion. I am completly against any more of this(even though I know the FCC is talking about it).
As to radio, we still have analog radio in the US with no plans to change as far as I know. The issue for me, at least with AM, is the programming is horrible(This is also true of most TV programming).
I have read that the UK is planning to go to only digital radio, but is having second thoughts-to many analog sets in use, especially in vehicles.
Old 05-05-2010, 09:45 PM
Hardly 'given' the fcc and gov made off nicely from the sale of this spectrum.
I cant see a point to digital only radio except the lower transmit power. Think about how much coverage would be lost with digital only radio. What a failure that would be
