Old 02-13-2010, 02:50 PM
It's in working cond. but hasn't been plugged in b/c electricity may be too strong
Once again, not mine.
http://jackson.craigslist.org/fuo/1595158140.html
I normally leave these idiots alone but I did ask for a picture or at least a make and model number. I also asked them how they knew it worked if it hasn't been plugged in.
Old 02-13-2010, 03:11 PM
Possibly a semi-valid concern... the average voltage in homes in the 40s and 50s was on the order of 110- 115v and has slowly crept up to 125v or so. Frankly, I do not worry about it and enjoy having a little extra width.
Old 02-14-2010, 04:40 AM
AUdubon5425's Avatar
You'd think that for $450 electro-boy would have cleaned it off already. SOunds like more bullsh*t. "Call to schedule a showing" indeed...
Old 02-14-2010, 04:49 AM
"Price is a little negotiable..."
Would they take $50?
Old 02-14-2010, 05:17 PM
Reece's Avatar
Reece Reece is offline
Need to try it out with some nice, gentle electricity.
Reece
Old 02-16-2010, 01:06 AM
cbenham's Avatar
cbenham cbenham is offline
You think maybe 50HZ????
Old 02-16-2010, 01:45 AM
IDK, why not 25Hz just for fun!
Old 02-16-2010, 09:11 PM
Reece's Avatar
As long as we're dropping in frequency, how about 0 Hz? Gentle as you can get, to be direct about it.
Reece
Old 02-16-2010, 11:18 PM
Actually, lower line frequency is hard on the power transformer. To a first order approximation, a power transformer designed for 120V 25Hz can be used on 240V 50Hz no problem, though all its secondaries will produce twice the voltage. And the opposite direction: a 120V 60Hz transformer can only take 50V at 25Hz. And a combo transformer designed for 240V/120V 50/60Hz can take 144V in 120V mode at 60Hz, if it could take 240V at 50Hz. In general, the higher the line freq, the smaller the core can be for the same power rating. Airplanes used 400Hz AC as that allowed the use of smaller and lighter transformers.
So fetch up some 400Hz... for some easy going electricity.
Old 02-15-2010, 01:55 AM
OvenMaster's Avatar
DTV blows
Gee, I love how seller tells us the brand name and model number... :eyeroll:
Tom
Old 02-15-2010, 02:06 AM
He still has not replied to my email. Maybe the electricity at his house was too strong and it fried his computer shortly after the ad was placed.
Old 02-15-2010, 04:46 AM
Lol
Old 02-17-2010, 02:25 PM
This is what I sent him:
Do you have a picture or at least a make and model number? And, how do you know if it's in working condition if you haven't plugged it in?
And this is what I just got back:
I can send you pictures of the TV. I did plug it in while showing it last weekend and the speakers make a sound but the TV does not come on. I don't know how to turn it on or if it does work. It was a gift to me and I have had it for almost two years.
Let me know if you still want to see it. I will send the pictures.
Thanks
Old 02-17-2010, 04:57 PM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
I'm anxious to see the pictures.
It scares me when they say it makes a sound. I'm sure the sound the sound that my Sylvania was making could have only been breakdown of paper caps and hum. Especially since the screen resistor was open on the 6Y6 output.
John
Old 02-18-2010, 01:24 PM
The seller may not know what he or she is talking about. Many if not most ebay sellers know little or nothing about electricity or electronics; most folks outside our hobby know just enough to unplug a piece of equipment that smokes, sparks or blows the house fuses when plugged into an outlet. I think this may have been the case with this seller. The person may not (probably didn't) realize that most radios, TVs and other appliances will operate on today's 120-volt electricity every bit as well as they did when the design center was 117 volts. Three volts (five if we are talking about 115 volts), after all, isn't that much of a difference; most appliances, radios, TVs, again, will operate perfectly well anywhere within a range of 115-120 volts, 60Hz AC. A certain maker of incandescent light bulbs (I forget the name) marketed a line of bulbs, some years ago (perhaps in the '80s), designed to operate on 130 volts AC. The claim was that these bulbs would last much longer on 120-volt circuits. I believe it, as I had one of these in a desk lamp. The bulb lasted some five or six years; when I finally had to replace it, the lamp base had somehow welded itself to the socket. I had the dickens of a time removing the bulb, having to literally wreck the socket to do so.
BTW, speaking of light bulbs, what (if anything) is there to prevent any electric light bulb from operating on DC power as well as AC? I have a desk lamp with a sticker on the inside of the shade that reads, "CAUTION: To reduce the risk of fire, use only a 60-watt Type A or smaller lamp. . . . 120V 60Hz AC only." I'm puzzled as to why there is a warning against using this lamp on DC power. Seems to me it should work just as well on DC as well as AC; after all, a lamp filament should light on either, as long as the voltage is correct.
