Old 07-21-2009, 11:44 PM
fsjonsey's Avatar
fsjonsey fsjonsey is offline
Living The Draper Ethos
12" Zenith b&w Portable- Plastic cabinet is Disintegrating
I picked up a mid 60's zenith b&w portable at the thrift store today. With "$5- as is" on the price tag I was expecting a dead set. Got it home, plugged it in, and of course it worked like new. It's a Zenith after all! It's a hot chassis set, has a continuous UHF tuner, and only has one transistor, in the UHF tuner. The set has one major problem however. The white plastic cabinet back is literally disintegrating. I can make deep gouges in the plastic with my fingernail, leaving a powdery residue behind. Removing and reinstalling the back to take a look at the filter caps caused the case screws to strip in their holes. I've never seen a plastic cabinet decay in this way before. Is this common problem with Zenith portables? I'll get some pictures and a model number up in the morning.
This device isn't a spaceship, it's a time machine. It goes backwards, and forwards... it takes us to a place where we ache to go again.
Old 07-22-2009, 12:07 AM
I've had many of these Zenith portables and I don't recall ever finding one with a disintegrating case. This set may have a million hours on it and the heat from the tubes may have done something to the plastic. The only sets that I remember seeing with falling apart cabinets were Sharp sets of the mid-to-late '90's.
Old 07-22-2009, 01:06 AM
OvenMaster's Avatar
DTV blows
I've seen that sort of behavior on other plastic stuff that was kept in very hot attics for many years... but never on a television set.
Tom
Tom
Old 07-22-2009, 02:12 AM
Too bad it's not a 16" set, I'd give you a 64 Zenith with a great cabinet but a busted CRT, well it was great, don't know after a couple years in the Garage rafters.
Old 07-22-2009, 02:28 AM
AUdubon5425's Avatar
Maybe it spent its life in a window - I've seen plastic interior pieces on cars that have suffered the same symptoms you describe.
Old 07-23-2009, 12:07 PM
Carmine's Avatar
Carmine Carmine is offline
...enjoys spaghetti.
Agreed. White interior Dodge Challenger/Plymouth Barracuda door panels were known for this problem. For some reason, UV protection was not included in the white plastic mix.
Maybe you could pour some of that thick, clear urethane over the plastic. (The kind that is meant to encapsulate knick-knacks in a coffee table, etc.)
From Captain Video, 1/4/2007
Old 07-22-2009, 06:23 AM
Me too, my truck has door panels like that. I also have one Zenith from about '65 that has the handle doing that. The CRT cracked on that one though.
Old 07-22-2009, 07:45 AM
Tony V's Avatar
Tony V Tony V is offline
I've seen this too but usually from something that has been stored in a hot attic for years.
Old 07-22-2009, 12:29 PM
fsjonsey's Avatar
It's really too bad the cabinet is wrecked, because the set displays a really good picture and the chassis even has it's complete set of original Zenith branded tubes. The thrift shop I got it from does a lot of business clearing out estates as well, so I bet this set was stored in someones attic or shed for a long time.
Old 07-22-2009, 01:33 PM
fsjonsey's Avatar
Well I'm an idiot.
It's actually a 12" set, Model number 13N15. It uses a 12BEP4 CRT. I must have been tired last night when i started this thread.
Old 07-22-2009, 02:19 PM
Time for a custom cabinet! Wooden "mini-console" maybe; mask the crt so it looks like a porthole; Remove the phonograph from an old side-by-side radio combo and install it there. If the radio has a lift-up lid over the phono, all the better-make it a mirror-lid set. Or, how about a plexiglass cabinet?
Old 07-23-2009, 11:26 AM
kx250rider's Avatar
REAL TVs have TUBES!
Sony had that problem in the 90s... I had several of them just crumble and fall out of my hands! You could take a piece of the plastic in your hand, and rub it to powder with your thumb. I have an '80s Sony KX-2501, which is starting to do that. I went to push it into a cubby hole on a shelf, and my hand pushed a hole in the back! It stinks like dirty football socks in a hamper on a humid summer day, so that probably means there's some kind of organic reaction going on in the plastic.
Charles
Old 07-23-2009, 09:01 PM
000
Old 07-24-2009, 01:39 AM
rcaman's Avatar
rcaman rcaman is offline
my boss sat down a 25" sharp in the floor and it literally fell apart. and he didnt drop it. from what i have heard sharp replaced some of those sets that were 7 to 8 years old. steve
Old 07-24-2009, 06:50 AM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
A lot of 1960s styrene cabinet tube radios do not survive today because of the tube heat making the plastic brittle.
How about some pictures of that set?
