Old 06-09-2008, 06:40 PM
Snade's Avatar
Snade Snade is offline
humble AK member
Slight shadow on my Chromacolor II picture - ideas ?
This is the Zenith Chromacolor II (1975) that I picked up from Doug. I love this TV and use it all the time.
In the area I have circled below, a greenish shadow has developed on the left side of the screen. It's kind of subtle, but noticeable when the TV is showing a white background.
Any ideas?
Thanks. Mark (aka Snade)
Old 06-09-2008, 06:56 PM
Do you have a degaussing coil? It may just need degaussing.
Old 06-09-2008, 07:04 PM
eberts eberts is offline
The effect is called "doming".
Doming is a phenomenon found on some CRT televisions in which parts of the shadow mask become heated. In televisions that exhibit this behavior, it tends to occur in high-contrast scenes in which there is a largely dark scene with one or more localized dark spots. As the electron beam hits the shadow mask in these areas it heats unevenly. The shadow mask warps due to the heat differences, which causes the electron gun to hit the wrong colored phosphors and incorrect colors to be displayed in the affected area.
Old 06-09-2008, 10:00 PM
Tony V's Avatar
Tony V Tony V is offline
Wasnt there a capacitor problem in these sets that caused this symtom?
-Tony
Old 06-12-2008, 04:09 PM
yagosaga's Avatar
yagosaga yagosaga is offline
VK Member
I agree. I have found this doming effect frequently when I do convergence adjustments with chessboard or cross hatch patterns.
http://en.wikipedia.org/wiki/Doming_%28television%29
In some cases, a new purity adjustment might fix this problem.
Eckhard
Old 06-13-2008, 04:15 AM
Eckhard
That set is older than I thought, it has the delta 90d tube.
Doming usually does not affect the delta's, mostly later inline tubes with slotted shadow masks.
Probably the condensor.
Old 06-09-2008, 10:43 PM
jpdylon's Avatar
jpdylon jpdylon is offline
<-- sucker for old sets.
I had the same failure on a CCII set I fixed. There is a 10uf / 450v capacitor in the power supply that opens. On most sets its part of the large multi-section can on the lower chassis.
Its failure will cause the exact symptom you're facing.
Jordan
Old 06-09-2008, 11:33 PM
Tony V's Avatar
Thats what i was thinking about as i remember you mentioning it before. Thanks Jordan
-Tony
Old 06-12-2008, 01:34 PM
Snade's Avatar
humble AK member
Jordan, thanks a lot. Could you look at the photos below and tell me exactly where to find this 10uF cap ? Thanks.
Also, if you could recommend an online source to buy the caps, that would be great.
Mark (aka Snade)
Old 06-09-2008, 11:58 PM
After looking at the picture better, it could be that cap. At first, I was just seeing that green spot. That 10 uF cap must have been a favorite because it was used in Zenith sets from the CCII's up through the sets of the '90's. It is a high failure part, especially in the late '70's and early '80's sets. If that section of your can is bad, do yourself a favor and change the entire can. I've learned this the hard way. Too many times, I've tried to skimp and only replace the bad section only to have another section give out in a week.
Old 06-10-2008, 09:45 AM
I think it's the bad cap too.
Old 06-10-2008, 10:31 AM
rcaman's Avatar
rcaman rcaman is offline
case closed it is a bad cap. it will greatly improve the pix quality when you change it. steve
Old 06-10-2008, 10:33 AM
Snade's Avatar
humble AK member
Thanks a lot guys. I'll change the cap.
The CC II picture is pretty amazing.
Old 06-10-2008, 11:42 AM
kbmuri's Avatar
kbmuri kbmuri is offline
I won't disagree with the crowd, it's probably that capacitor. However it does look like you've got an electric appliance sitting on top of the left half of the TV (most of it is cropped off of the photo). Real quick, remove the appliance and see if the green goes away. Might just be a small EM field.
Do not attempt to adjust your set.
Old 06-10-2008, 11:50 AM
Tony V's Avatar
That "appliance" is a Zenith radio I dont think that would cause it as several of us have radio's and such on top of our tv's and dont have any problems. It would seem to me if it had a magnetic field it would be across the top...not down the left side.
-Tony
