Old 05-12-2008, 03:22 PM
Boobtubeman's Avatar
<---WANTED: Motorola 17P6
Lol!
Check out this Ebay item:
#220234398592
They claim theres sound but no picture, Can YOOOUUUuuuu guess why?
hehehehehe
Steve
Old 05-12-2008, 03:39 PM
Ouch!
By coincidence I just received info on one like this (in nice shape) up for grabs in Westport, Massachusetts if anyone's interested.
Old 05-12-2008, 04:19 PM
Talking
They watched too many shows on the CBS TV network?
Old 05-12-2008, 05:18 PM
MRX37 MRX37 is offline
Originally Posted by wa2ise View Post
Looks like an eyeball almost...
Old 05-12-2008, 05:50 PM
grimer's Avatar
grimer grimer is offline
Old 05-12-2008, 04:49 PM
"That parrot wouldn't "Voom" if you put 5000 volts thru it..." (grin)
Old 05-12-2008, 05:30 PM
7"estatdef 7"estatdef is offline
So what crt does it use? It's about 45min from here.
Terry
Old 05-12-2008, 06:18 PM
kbmuri's Avatar
kbmuri kbmuri is offline
Terry
This one has a 16LP4. Looks like probably the same TV in a different cabinet. This one is model 50T1632. If that helps.
Old 05-12-2008, 07:12 PM
LOL! thats exactly what i was thinking wa2wise, i was thinking if they turned the tv upside down, and rocked the CRT till it rubbed the phosphor off the upper portion, (a crude etch-a-sketch) a CBS exec would want this for their office
Steve
Old 05-12-2008, 08:30 PM
Old1625's Avatar
Old1625 Old1625 is offline
The byword of the old days in the TV shop was "Watch the Tube!!!!"
Oh well...those were the good ol' days....
I carry old console floor models from one place to another with the front toward me--carefully. Table models I usually carry with the top side toward my belly and the screen-side pointing down, with the neck of the kine at my closest scrutiny at all times in transit as a result.
That neck end sticks out, and has a nice little "bra cup" on the cardboard backing of most sets. It is the "Achilles Heel" of the kinescope. And sticks out like the utmost amplification of the proverbial "sore thumb"--or gouted big toe....
Sometimes it gets slightly nudged, and an epoxy job will stabilize the cap at the end, lest the thin wires coming out of the glass envelope break from too much flexure. I've done many of those repairs--including removing the cap, delicately filing down the glass around a broken-off-at-the-glass lead to wrap another lead and solder, then re-extend all the leads through the hollow pins of the connector cap, and re-affix the cap with epoxy or whatever. Too many times.
Other times the nudge simply has too much force behind it, and one hears the hollow rush of air into the kine as its little exhaust tip between the leads gets broken...Then the inevitable long walk to the front of the set from the back to watch the blow pattern in the phosphor....
Oh well....
