Sony Trinitron KV 32s15
Hi Guys,
I know very little about tube TV's. Anyway, this is a 32" set and has a little color at the two bottom corners (Greenish the pinkish) could this be the shielding on the speakers? Quick fix? Thanks ***Addendum*** Stupid newbie question....I cycled it on and off a couple times and internal degauss cleared it up.
Jim Speaker Junkie: * 1981 Cornwalls * Forte I's * Magnepan MGII's * NLA's * CV D9 * BA T930II * BA T830 * AR4x * |
Sounds like the CRT needs degaussing. Also, check the degaussing thermistor inside the TV for loose solder connections to the PC board. The degaussing thermistor is located in the power supply, close to the two lead plug leading to the degaussing coil around body of the CRT. The thermistor will probably be a small, black square case.
Will do.... If it keeps happening.
For now it's cleared up. I just picked this set up this morning for $50. Everything looked great when I went to look at it. Let it play for 20 minutes before I agreed to buy it.
