Bought this set for 50 bucks a few months ago. The picture is "stretched" on the left side, and the hue is WAY off (too much red, blue looks "weird"). Called a place that does tv repair, they said my tube was done; I love the way the cabinet looks, and it's sound quality. What can I do to get it perfect again? I appreciate any help and suggestions you can give me. Thanks guys and gals
From a value standpoint, I'd sadly have to say junk it if the tube is gone. It's going to be hard to find a decent 710AB22 for it, and a new one is about $275. I agree with you that it's a nice set though.
Charles
Collecting & restoring TVs in Los Angeles since age 10 |
As others have said if the CRT is bad it's junk. Turn the color down all the way, if you have a good B&W picture the CRT is probably okay (all three colors are needed to make white). If you can't get white then the CRT is probably bad and not worth spending any money on (unless money is no object and you must have this set working regardless of the cost).
Okay, What about getting a tube from another set that uses that model (part the tube out of another unit with the same tube)? Can this be rejuvenated? B&W is good, a little pinkish though. The corners of the tube aren't discolored either. Thanks again.
If you are lucky enough to find a good tube in another set, you should be able to swap them with no problem. I used to do it all the time on sets that would have otherwise gotten junked. In fact, I did it to a 27" 2004 Sanyo flat screen the other day. I had a JVC branded tube with the same number as the Sanyo tube and it worked perfectly. |
