Old 12-02-2005, 08:08 PM
Chad Hauris's Avatar
New Zenith 14A10C29 (late 1960's color)
Here is a Zenith 14A10C29 I found at a secondhand shop today for $10.00. Looks like a replacement CRT and in very good shape...howver HO tube gets red hot, has sound but no HV. I think I do have a flyback from a junk set that I can sub into it, though. The store had it plugged in and they said it worked last week, hopefully it did not "fry" for hours when someone turned it on...
Chad Hauris
Old 12-02-2005, 09:15 PM
RetroHacker RetroHacker is offline
Electronics Accumulator
Wow - that is a nice looking set. Good find! Hope you get it working again, would love to see that one going. Is that an all tube chassis? Seems to have more tubes than the typical hybrid, and I'm assuming that there are more tubes hiding in there behind the CRT neck and yoke in that picture. But sets of this vintage seem to have a couple transistors hiding in there somewhere. I have a 23" B&W Zenith, and the tube chart instructed "Replace all tubes and transistors with identical replacements". It wasn't until I got the Sam's that I found the set's one transistor lurking in the UHF tuner...
-Ian
Old 12-02-2005, 10:11 PM
This set does have some transistors plus some of the old round cased IC's.
Chad Hauris
Old 12-02-2005, 11:50 PM
peverett peverett is offline
I have a Zenith that is very similar, but with a grey metal case. Mine works well on VHF and well on UHF after warm up. It has a transistor IF section.
If you happen to need another flyback and do not have one, I do have a couple spare chassis that are for this set or one very similar. I have already used one of the plastic High voltage tube backing as the one in the set I have working was arcing through.
