Old 05-14-2005, 10:58 PM
eBay: Sears Color Portable
Passing time & happened upon this one, in Arizona. C.1970, solid state competitor for the Portacolor.
http://cgi.ebay.com/ws/eBayISAPI.dll...177458288&rd=1
Old 05-15-2005, 01:15 AM
tv beta guy
Guest
Posts: n/a
I have one of those. I bought it off of Kamakiri last year. It has an instant on CRT, which I plan on modifying so it isn't. This TV is actually smaller than the Portacolor, only 8.5", has a delta gun CRT, full DC restoration, AFC, automatic chorma, and automatic tint. Dot pitch on this set is really fine too. Mine was made sometime in mid 1972.
Old 05-16-2005, 01:46 AM
Instant-on TVs
I hear ya. I didn't then (in the '70s, when instant-on first appeared in TVs) and do not now like instant-on either. Besides wasting electricity, these sets could create fire hazards if anything shorted in the filament circuits. Personally, I wouldn't want an instant-on TV keeping its tubes warm while I was sleeping or away from the house, but then again that's why most of those sets had a switch somewhere to defeat the instant-on circuit when it wasn't needed or wanted. The other thing I never cared for with instant-on was the habit the instant-on diode across the set's on/off switch had of shorting whenever lightning hit near (or, heaven forbid, on) the power line the set was connected to. Since this diode was in fact in shunt across the switch, when it shorted it effectively locked the switch on. The only way to turn the set on and off with a shorted instant-on diode was with the AC cord, by plugging it into and pulling it out of the socket, respectively.
One of the best things TV manufacturers ever did, IMO, was to eliminate the instant-on feature once and for all by, IIRC, the late seventies or early eighties (I'm not sure exactly when). One other thing some people did, if they knew how to do it and where to look, was to simply cut the diode completely out of the circuit, even if said diode was still good (certainly if it was shorted). This removed the instant-on feature without disturbing the normal function of the switch (or restored the switch function if the diode was bad). Of course, when TVs went to completely solid-state circuitry as they are today, the sets are practically instant-on (I say practically because of the warm-up time for the CRT filaments, which usually is not too long--my set's picture usually appears in well under a minute after I push the power button), with no need whatsoever for power-wasting instant-on circuitry. Today's sets are never completely off anyhow, even with the power switch off (because of the remote control receiver and probably memory retention circuitry for the tuner and on-screen controls), but there is no problem with fire hazards (and very little added impact on the owner's electric bill as well--the set won't use that much more power than its maximum rating, or perhaps, even likely, the power used by the remote, etc. is figured into the total current draw as shown on the back of the set), since the memory-backup systems and the remote receiver use so little power. I don't know how much off hand, but I think it would have to be well, well under one volt DC.
BTW: I'll be darned! I thought that little set looked familiar. I remember seeing it in one of Kam's posts a while back (before you bought it from him, of course), with the same color-bar test pattern on the screen as appears in your pic of the set. Hmmm.
Old 05-16-2005, 03:12 AM
My heavens, Bryan, where do you keep all your old TVs? Every time I log on to AK, or so it seems, you have another set (sounds like Doug with all his Zeniths). Your basement must be huge.
Old 05-16-2005, 03:26 AM
heathkit tv
Guest
Posts: n/a
Ya know, I kinda like that lil cutie! I wonder who actually made it, the photos show clearly that it was made in Japan.
Anthony
Old 05-16-2005, 05:10 AM
tv beta guy
Guest
Posts: n/a
It was made by Sanyo.
Old 05-16-2005, 07:38 AM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
Sears Color TV
I won the little Sears set on Ebay. It appears I was the only bidder. I am just nuts about small screen sets and this one looks great. I bet the chassis is tightly packed. Small transistorized sets of that era usually are. Anyway it will be fun to work on.
Old 05-16-2005, 03:21 PM
tv beta guy
Guest
Posts: n/a
Congrats Compucat! Here is a pic of the insides. It is packed...
Old 05-16-2005, 06:35 PM
tv beta guy
Guest
Posts: n/a
This started to make me wonder. Does anyone know what is the smallest color TV to utilize a delta gun CRT?
Old 05-16-2005, 10:09 PM
compucat's Avatar
1949 Motorola 9VT1
Sears TV
Good golly! What have I let myself in for? I knew it would be packed but that is something else. It has been about twenty years since I worked on a set that had wirewound pots for convergence. I think I might disable the instant on when I get it. I only have one set so far that has it, a 9" orange Panasonic from the early '70s. There are both tube and transistor versions of this same set. Mine has tubes but I don't like to leave it plugged in as I don't want to heat damage the pc board. Tubes and pc boards are a bad combination.
Thanks for taking the time to open your set and show it to me. I'm always interested in such things.
Old 05-16-2005, 09:27 PM
kc8adu's Avatar
kc8adu kc8adu is offline
i have a 250xb22 which is about 7"
it has a small neck like an inline but is a delta gun.
it is from a hitachi set
email for more info
Old 05-24-2005, 10:50 PM
jstout66 jstout66 is offline
I would just try to adjust the vertical height control a tad. No need to re-cap if you don't have to. It's pretty packed in there. I have posted my opinion on this before, but I think re-caps on newer stuff (mid 60's and on) is a waste of time and money. Unless it is a specefic cap that failed I believe "If it aint broke don't fix it" Cool set by the way!
Old 05-24-2005, 11:26 PM
tv beta guy
Guest
Posts: n/a
I had the same problem with mine when I got it. It had just a slight bit of vertical reduction. Tweaking the V. Height fixed it, and that little TV has been working great for almost 9 months now with no problems.
Old 05-25-2005, 12:58 AM
heathkit tv
Guest
Posts: n/a
You got that wrong, it should be "If it ain't broke we can fix it anyway" ARG ARG ARG ARG ARG (Tim the Toolman sez so)
Anthony
Old 05-28-2005, 09:54 PM
compucat's Avatar
1949 Motorola 9VT1
Color Inconsistency
I have been using the set for a few days now and I notice the hue changes from one program to the next or between the commecial and the program and channel to channel. Is this normal? I seem to remember color TV in the seventies being this way. This Sears set is great but it is very Portacolor like in its color consistency.
